Clay Bar?????
Most high-end wax producers also provide clay bars, and they recommend using their detail spray as a lube for the clay bar. However, 6-10 drops of car their car wash product in 12 oz of water in a spray bottle will provide the same lube quality and is a LOT cheaper too! Although DAWN is "THEE" detergent to use to remove old wax and finish, I don't belive I would use it as a lube for clay barring. I'd stick with the car wash product, but maybe a pro would have some other suggestions and chime in here.
Steps:
Wash car w/ DAWN to strip off old wax, etc.
Follow the directions for use of the Clay bar, using the diluted car wash in a spray bottle as a lube.
Keep kneading the clay bar so as to keep as clean a clay surface as possible touching the paint**.
Rinse (or wash) the paint and dry it
Seal the paint, and wax or polish w/ your favorite "shine" product, according to their instructions for use.
Choose the right wax or polish for your situation and you won't have to do the clay bar bit very often. (That's why I choose to use a high-end polish product, as it does not soften in the sun and act on dust as flypaper to flies!).
You'll like the clay bar results. (These cars happen to have the Zaino polish on them)
P.
Grit is added to your paint every time you take that first dirty soapy sponge and dunk it into your new bucket of soapy water- all the dirt just got mixed into your bucket and you are picking it all back up and wiping your car with it. Just like micro sand paper.
To do it right and stop swirls and grit-dunk sponge in the clean soapy water, wipe car, then dunk sponge into 2nd bucket and squeeze out. This 2nd bucket has the strainer- and the dirt will fall below the strainer for future dunks. Then CLEAN sponge goes into CLEAN soapy bucket- and repeat.
Before you Clay Bar- do a test (and note- clay bar has NOTHING to do with those shines you see)- it's actually a micro stripper)
use a grocery bag- put it on your hand- and then slowly glide your finger tips along the paint; If the bag wants to grab and not slide- you need to clay bar. If it slides- do not clay bar- you're wasting time and energy.
If you have swirls in the paint, clay bar is only the first step. (use a halogen or bright flood light, angle it and look at your paint- see the swirls?) People think swirls are from buffers- but they are from CHEAP micro fiber towels and dirty sponges when washing. (good micro fiber towels are not from Walmart or Pepboys- if you pay about $1 for each micro towel, they are not good ones- if there's a tag on the micro towel- it's cheap.
Need to buff out swirls with a (I recommend) Porter Cable 9424 Oscillating Buffer and 3 drops of your favorite 'swirl remover'. Wet the pad with your favorite detailer, and buff 1' areas at a time. ALWAYS start and stop your buffer while on the car- NEVER start your buffer and then touch the car. Work the buffer top left of the 1' square, and snake it down the 1' area, from left to right, right to left, then bottom to top, top to bottom. Work it 3 times this way, always finishing from the front to back of the car. Re spray with Detailer and repeat 2 more times. Then wipe off excess detailer with micro towel.
After all this work- now you can wax. Just keep washing your car the correct way, and you'll find you won't need to clay bar or machine buff for years to come. Of course, you've got to wash your car regularly, and it won't hurt to keep it garaged or covered.
Here's my car- and it's FULL of swirls- before I buffed it- didn't need clay bar and the swirls are hard to see, but near the sun light bouncing, you can see them.
http://www.bugmanweb.com/c6/c6index.html
Claybar shears off the contaminates in your paint. But, it'll also strip the protection from your paint. If your car isn't bad, you can get a light duty clay kit [Mothers or Meguiars from any auto-parts store or walmart.
Waxing is more a maintenance item. You redo it anyway, even if the old wax is still around. Like changing oil. You change it even though the old oil still has life in it.
Clay removes contaminents on the paint. That's it. It doesn't protect the paint, fix swirls, remove oxidation, or anything like that. If you don't have anything bonded on the paint, there is no reason to clay. With a car like a Corvette that is generally garaged, well waxed, and washed often, it is possible you will never need to clay it again.
Since you can scratch the paint with a clay bar, I'd just say there is no reason to do it unless there is something you are trying to correct.
