Garage painting
Garage painting
My vette is off to the shop to get some paint on the hood and I figured I would redecorate her room while she was gone.... Who here has experience with garage paint. I am looking to do a gray with some flakes epoxy paint the concrete floor to tidy up the room. What systems work best and where can i get them
Location: The reason time exists is so everything doesn't happen at once
I used the Rustoleum Garage Epoxy availabel at Home Depot. It's very easy to apply but preparation is the main ingredient. Make sure the floor is prefectly clean and free of grease, oil or any other contaminants. The acid wash that comes with the kit is required, no matter how clean or new the floor is.
I really like the tiles and I wanted to checkerboard the thing but there were two reasons why I didnt.
1. Cost WAYYYY more expensive to tile it VS paint it
2. Paint should be more durable, easier clean up and I dont have to worry about cracking a tile if I drop a wrench or when I choose to jack the car up in the garage.
I really like the fancy floors and the nice garages just can't imagine working in one. I weld, paint and do bodywork in mine and that floor would be junk in no time. I would like to have an attached garage layed out like that then a 50X90 outback for work. I'd also like a FAT FREE LOW CALORIE Papa Johns Pizza that tasted EXACTLY the same as a regular one I would also like a PROFESSIONAL Football Team in Cleveland
1 Post
I used the Home Depot epoxy mix before I moved into my present house, I cleaned for 2 days and did everything right and waited for a week for it to dry and about after a month my 91 started to pull paint off it, SO, now I will try the tile next.
St. Jude Donor '10
You're thinking of ceramic floor tile- Most use Vinyl or Rubber floor tiles- Vinyl stick on tiles cost about $1 psf- agreed, more than paint- but you won't ever crack these.
1 Post
that sux! I can say that I have had no problem with mine, I could tell right away when the paint was going on that it was soaking down into the concrete very well. Traxx, maybe you had a sealed floor and you didn't etch it properly with acid wash first? Just a guess..
Location: Why are there squished peanut butter cups in my underware?
Nice cabinets. (Even if the doors on the tall cabinet are on upside down.)
My latest issue of Corvette Enthusiast (Dec '09 issue) has an ad in the back for garage flooring that comes on a big roll (like carpet).
If anyone has that issue then check it out for more info.
I just mailed that magazine along with some goodies to a lady in our armed forces in Afghanistan so I am unable to reference it.
Here's my garage...
The cabinets are from Moduline. I got the epoxy for the floor from UCoatit. The back-splash on the counters is SlatWall covered in brushed aluminum.
I work on the cars in here all the time...a quick wet-mop and it looks fine.
Don't think I'd ever weld in here though...pulling it outside is the only way I'd do anything like that
Preparation is the key to a great job. I rented a concrete wet grinder for a day and went over the entire surface to etch the surface for maximum adhesion. Then, like everyone else said...clean, clean, clean...then acid etch. I used a layer of their floor leveler as well to make it as smooth as possible.
Here's my garage...
