Spark Plugs???
Old Oct 3, 2009 | 07:32 PM
Fight or Flight's Avatar
Fight or Flight
Default Spark Plugs???
Question?? Does it matter what spark plugs you use. Should I spend the extra money for the "quadro" or the "dual" spark plugs? Any help would be appreciated. I have an 84' if that helps.
P.S. What spark plug wires should I use?
Old Oct 3, 2009 | 07:40 PM
86IndyCarVette's Avatar
86IndyCarVette
If you're staying stock, I'd stick with AC Delco or Bosch.
As for plug wires,
Dave
Old Oct 3, 2009 | 07:47 PM
tblt44's Avatar
tblt44
stick with a/c delco's
Old Oct 3, 2009 | 10:45 PM
jimg's'93's Avatar
jimg's'93
My last wire set were the Taylor 8mm Spyro-Pro's, but I recently moved to the MSD 8.5mm Super Conductor's only because I needed to have a custom length. Otherwise, the Taylors were great and pretty reasonably priced.
Old Oct 4, 2009 | 03:33 AM
Fight or Flight
Ok thanks a lot!
Old Oct 5, 2009 | 11:17 AM
H P Bushrod's Avatar
H P Bushrod
Moderator Emeritus
St. Jude 15 Year Donor
CI 5 thru 12 Veteran
St. Jude Donor '09 thru '23
Any copper core plug will do fine. Stay away from the gimmick plugs unless you like wasting money.
Old Oct 5, 2009 | 11:47 AM
pr0zac's Avatar
pr0zac
if you are spending more then $3 a plug you are wasting your money.
Old Oct 5, 2009 | 11:55 AM
glava2876's Avatar
glava2876
When I bought my car it had Bosch "gimmick plugs" which didn't look too bad with a nice light tan coloring- but the car just seemed to run rough cold. I replaced them with standard AC DELCO plugs -it ran and idled great!
The wires were not too bad and didn't look too old, but I have also replaced them and the the cap/ rotor -just so I know everything is current.
My car is all stock, so I didn't go with any real performance parts, except an Accel cap because it uses brass.
Old Oct 5, 2009 | 03:09 PM
383tpimachine's Avatar
383tpimachine
only thing you need to worry about is if your getting away from NA
high compression, nitrous, boost need colder plugs
and they still shouldnt cost over $4 a plug
Old Oct 5, 2009 | 03:27 PM
Vette Jockey's Avatar
Vette Jockey
Roadster Madness. 😠
St. Jude Donor '13, '20-'21
I do not know if it was a gimmick, but Horsepower TV did a dyno test with E3 Spark Plugs. They used the same engine with different spark plugs. The E3 gave the best boost in horsepower and gas mileage.
Old Oct 5, 2009 | 03:29 PM
383tpimachine
was it high compression or boosted?
and a good tune does the same
Old Oct 5, 2009 | 04:36 PM
1973Jasonr's Avatar
1973Jasonr
I just replace my 94 with Champions. They work great.
Old Oct 5, 2009 | 04:43 PM
Vette Jockey
Roadster Madness. 😠
It was a test bed engine tuned to maximum output. Horsepower TV uses it to check the claims of the manufacturer of different products.
The test was a few months ago so I do not have all the details. I just wrote down the plug name to give it a try next time I need plugs. They do a lot of re-runs so I will keep an eye out for more detail. It is on cable on Sat & Sun.
Old Oct 5, 2009 | 04:49 PM
383tpimachine
check the price for the e3s and be amazed. I went with UR6 NGKs
lil colder for nitrous
Old Oct 5, 2009 | 06:50 PM
pr0zac's Avatar
pr0zac
you are not going to see a gain in hp from spark plugs.
Old Oct 5, 2009 | 10:35 PM
383tpimachine
dyno your car without spark plugs. then with. There will be a HUGE difference
Old Oct 6, 2009 | 02:08 AM
Vette Jockey
Roadster Madness. 😠
To Spark Plugs???
Old Oct 6, 2009 | 08:41 AM
jaa1992's Avatar
jaa1992
From: Life is just one big track event. Everything before and after is prep and warm-up and cool-down laps
Cruise-In III Veteran
Cruise-In IV Veteran
St. Jude Donor '12
DO NOT USE BOSCH!!!! you will be replacing them in a year!
No need for a gimmick plug
Plain old copper AC/Delco, if you want to spend more I like the NGK platinum.
Old Oct 6, 2009 | 09:13 AM
mazdaverx7's Avatar
mazdaverx7
i'm suprised to read that someone here uses NGK platinum plugs. they are excellent plugs and i use NGK plugs for my RX-7's and my Camry. my 84 has AC Delco plugs and they seem to work great! i may do more research on the NGK but i guess for now i'll stick with the oem replacement.
Old Oct 6, 2009 | 09:45 AM
VETTEHIGH's Avatar
VETTEHIGH
Autolite 3926
