Flameball Shift Knobs
Old Feb 23, 2002 | 06:05 PM
dmalhi1's Avatar
dmalhi1
Default Flameball Shift *****
i've noticed many of you using these things and i am making a bit of an inquiry for a friend. exactly how do these things light up? the site says its via a 14volt bulb, but how is that bulb powered?? where do you run the power wiring through the shifter?
Old Feb 23, 2002 | 07:48 PM
Mr Mojo's Avatar
Mr Mojo
Elite Torch Red Member
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
Default Re: Flameball Shift ***** (dmalhi1)
I haven't hooked mine up yet, but in the later C4's anyway(not sure of the early ones) There are 3 wires in the console which can be used for accessories. One is hot, one is ground and one is hot when the key is on(something like that).
Old Feb 24, 2002 | 01:58 AM
dmalhi1's Avatar
dmalhi1
Default Re: Flameball Shift ***** (Mr Mojo)
cool thanks frank
To Flameball Shift Knobs
