headlight button
Old Oct 9, 2009 | 02:33 PM
richmond1's Avatar
richmond1
4th Gear
Default headlight button
I want to install a wood dash kit on a 87 c4 and i need to remove the headlight button to install it, is there a way to remove it ? or do i have take the dash apart to get to the switch.
Old Oct 10, 2009 | 12:26 AM
kenv's Avatar
kenv
From: levittown pa. usa Even a bad day with my `Vette, is better than a good day at work
St. Jude Donor '10
If you are talking about the headlight ****, its just spring loaded to the switch shaft. Pull the light switch to the "on" position, & you will see a small piece of metal inside theknob resting against the shaft. Just depress the piece of metal with a small screwdriver while lightly pulling outward on the ****, & it should slide right off. (at least mine did)
Old Oct 12, 2009 | 06:51 PM
richmond1's Avatar
richmond1
4th Gear
thanks that worked great
Old Oct 12, 2009 | 08:07 PM
kenv's Avatar
kenv
St. Jude Donor '10
Old Oct 14, 2009 | 02:41 AM
redrose's Avatar
redrose
now take your little screw driver to your local junk yard and select a **** that you can actually grip with your fingers, from a myriad of late 80's vintage GM econoboxes than have ***** with same mounting method, many with 'fancy' chrome/non-slip grip/etc
To headlight button
