Replacing cracked windshield
Old 10-11-2009, 01:00 AM
Eddie & the Cruisers
Eddie & the Cruisers's Avatar
Default Replacing cracked windshield
Searched to no avail. What to look for to get a windshield replaced by a reputable shop?
Does the weatherstripping need to be replaced if you have no leaks before change? Any special kind of glass? Anything else?
Old 10-11-2009, 11:25 AM
silverja
silverja's Avatar
Default Try using Advanced Search
You will find great answers to your question by using this forum's Advanced Search function on "windshield replacement". You will find it at the top of the screen after loggin in as a member. Here is a screen shot on how:
Best of luck.
Old 10-11-2009, 01:35 PM
floridamale
floridamale's Avatar
If your weather stripping can't be removed without ruining it yes, be extra careful removing the reveals along the top and the A pillars they bend very easily.
When using advance search it's best to use quotation marks at start and finish of your search.
IMPORTANT: Use quotes around keywords to get better results. Examples: "fuel pump" ; "fuel pump installation"
Old 10-12-2009, 12:51 AM
Thanks, guys, I forgot about Advanced Search. At least it keeps you in the C4 forum. Still not impressed with the search function.
Old 10-12-2009, 07:40 AM
RedVette84
RedVette84's Avatar
I'd ask alot of questions from them before I let them touch it. Like how much experience do you have with vettes?
Old 10-12-2009, 08:30 AM
RollaMo-LT4
RollaMo-LT4's Avatar
2021 C4 of the Year - Unmodified Finalist
St. Jude Donor '10-'11-'12-'13-'14-'15-'16-'17-'19-'20-'21-'22-'23
If they have never done a C4 before, I wouldn't let them touch it.
Quite a few horror stories on windshield replacements.
Old 10-12-2009, 10:07 AM
harley 1951
harley 1951's Avatar
Find the right shop and then remember, if it's not an insurance job, there is a lotta wiggle room on glass.
Old 10-13-2009, 12:16 AM
Would it be best to remove the garnish trim, rubber seal, the reveals (top and sides) and the seal channels yourself, and just let them remove, replace and seal the glass in the frame?
Then install the reveals, seal channels, the rubber seal and the garnish trim yourself.
Old 10-13-2009, 11:02 AM
c4cruiser
c4cruiser's Avatar
If you go to a reputable shop, let them do all of the work. That way, if something is screwed up or is damaged in the installation process, they get to cover it. If you have concerns about the work they will be doing, talk to the shop manager.
Also have him watch while you point out what condition all of the pieces are in beforehand and that you expect to see those pieces in the same condition when the job is done. If you want to buy replacement trim parts, that's up to you but have them with you when the car goes in and tell the shop to use the new pieces.
It's possible that the shop may find some rust spots in the windshield frame once everything is removed. That should be taken care of before everything is put back together. Ask the shop about this possibility and what they would recommend or do to repair any rust damage.
R&R of all of the trim can be difficult if you don't have the experience and the tools to do that part of it.
Old 10-13-2009, 11:58 AM
floridamale
If the shop doing the work knows about Corvettes they should know what to look for, if they don't you need to find a different shop
Old 10-13-2009, 01:06 PM
FireRoc
FireRoc's Avatar
We had to the windshield replaced on our '94 C4 about two years ago. It cracked i nthe middle of thewinter when the wife was clearing snow/ice off of it.
A couple of suggestions/observations.
Make sure the shop does NOT use off-shore (China) glass. Ask for the OEM glass. This might cost more, but IMHO better in the long run.
The urethane foam/glue needs to set up overnight to gain sufficient strength. If the shop does not want to keep the car, I would be looking elsewhere. The shop we use will refuse to do the glass work unless you agree to leave the car with them overnight.
The trim/reveals are very fragile and VERY VERY expensive to replace. Make sure the shop treats these carefully and knows how to work with them. Our needed some re-work on re-installation, but look good now.
Do not be surprised if there is some rust in the windshield frame. Ours had rust along half of the header frame and had to be sent out to a body shop for repairs. I think this comes from the way GM repaired water leaks at the factory, as the shop found a bunch of stuff stuffed into the header frame from the inside. Sure it stopped the leak but let water sit on the header and do its "dirty work" over time.
Old 10-13-2009, 11:56 PM
Thanks. Y'all have answered many of my questions. I had heard about the cheap glass from China. Hope there isn't too much rust.
Old 10-14-2009, 09:47 AM
samsonb
samsonb's Avatar
Do you have any pics of the rust? When I got my 89, the PO had replaced the windshield. I had to get it reset as it wasn't pushed up high enough. I did have water leaking in past the weatherstrip retainers. So, I had to get that seam sealed up where the A pillar trim goes. I also had to seal up the open seam on the outside where the top windshield trim overlaps the A pillar windshield trim as I noticed water getting in through there.
I did notice a crack in this windshield though, so it will probably need to be replaced at some point. Right now, the crack is in the lower part in the black area on the passenger side. The crack is on the inside of the glass. Kinda sucks as I just got all the leaks fixed and will have to go through it again if I get the windshield replaced. I may talk with the dealer as his glass man seems familure with these as he was the one who noticed the windshield wasn't installed properly and sealed up the passenger A pillar leak. Though, he didn't do the driver side for some reason, so I had to fix that myself.
Old 10-14-2009, 11:01 PM
FireRoc
FireRoc's Avatar
Sorry no pictures of the rust. It was just surface rust though and was easily fixed.
Old 10-14-2009, 11:25 PM
samsonb
samsonb's Avatar
Was it hard to fix? And what did they do, just grind the rust out? Or use that rust converter stuff?
And where is it that the water gets in to cause the rust? Past the windshield, past the weather stripping, or past the weather stripping retainers?
Old 10-14-2009, 11:33 PM
jrzvette
jrzvette's Avatar
Location: The reason time exists is so everything doesn't happen at once
Make sure you use a reputable shop. The windshield is an integral part of the airbag system. A poorly installed windshield can be blown out by a deploying airbag and you can wind up as a hood ornament.
Old 10-14-2009, 11:36 PM
socalman
socalman's Avatar
St. Jude Donor '10
This forum is over 10 years old- every possible question has been asked. If all anyone did was "search" there would be no new threads.
To Replacing cracked windshield
Old 10-15-2009, 12:39 AM
Mr. Peabody
Support Corvetteforum!
Mr. Peabody's Avatar
C4 of Year Finalist (appearance mods) 2019
I had the windshield in my 95 replaced two years ago after several small cracks. I asked at the pro shop that does all the mechanical work on my vette who they would recomend and they gave me the name of a guy who comes and does it at your house. This gentlemen came with an outstanding recomendation.
I called and told him that I wanted nothing but PPG. He came to where I work and replaced the glass in two hours.....
He loosened the side trim and then took out the windshield from the bottom and put in the new one from the bottom reversing the process without touching anything else .... he did have several very special tools.....now let me tell you that my vette is a year round daily driver and it rains 6 months a year here in Seattle and not a single drop or leak anywhere at all and this is now 25,000 miles ago.
It's all in knowing how .... he told me that he's replaced winshields in over two hendred vettes and frankly I believe him.
Go to a shop that does lots of work on vettes and ask them for a recomendation
Old 10-15-2009, 05:36 AM
samsonb
samsonb's Avatar
How much did that cost?
You must live in a big city if your guy has done 100's of Vettes. I'd be lucky to find someone who has done even one C4. I think I've only seen 5 or 6 C4 Vettes in my town over the past 10 years.
Old 10-15-2009, 06:12 AM
Greg Gore
Greg Gore's Avatar
I had a w/shield replaced in my 96 several years ago. I searched the forum archives then and saw several posts that describe the process. The standard recommendation was find someone who had done a C4 before so I called the local Chevy dealer's body shop manager and he gave me the name of someone they call for the Corvettes. He came to the house and did the job here and it was obvious he knew what he was doing. If the tech has never done a C4 before it is highly likely he will damage the w/strip retainers trying to remove them because they have to be removed. It is recommended you plan on replacing the w/strip at the same time as it has to be removed to get the w/shield out and it is likely it will be torn in the process. It probably needs to be replaced anyway unless you recently replaced it. They will have a special black primer paint to paint the w/shield frame if there is rust (after they scrape the rust off of course). Mine had minimal, your mileage will vary.
Quick Reply: Replacing cracked windshield
