problem restarting
Old Oct 12, 2009 | 02:33 PM
JimTranter's Avatar
JimTranter
6th Gear
Default problem restarting
After driving the vette for a while it dosen't want to restart, it won't idle and the mixture smells rich. After it cools down it's okay. Any suggestions.
Thanks Jim
Old Oct 12, 2009 | 02:51 PM
SQUIRMIN VERMIN 84's Avatar
SQUIRMIN VERMIN 84
From: Supreme Soviet Peace-Loving Pipple's Kollektive of Seattle Wa
is your vette any particular year?
Old Oct 12, 2009 | 03:53 PM
JimTranter's Avatar
JimTranter
6th Gear
1993 sorry forgot to add that.
jim
Old Oct 12, 2009 | 08:41 PM
floridamale's Avatar
floridamale
Run an injector resistance & fuel pressure test look for the sticky top of Tech Section to explain what to do
Also there is a lot of information to be found using search
Old Oct 13, 2009 | 01:34 AM
jabez's Avatar
jabez
Many years ago I had a similiar problem. My fix was to replace the ECM. As soon as that cooled off everything was fine. Had me parking under trees and near buildings to cool things off sooner. Replaced ECM (as someone suggested here) and never had that problem again.
Old Oct 14, 2009 | 04:39 PM
JimTranter's Avatar
JimTranter
6th Gear
Thanks, was hoping it wasn't the ECM. I will have to send it out to Zip Corvette to be rebuilt.
Old Oct 14, 2009 | 04:56 PM
Sweet 90's Avatar
Sweet 90
Did you listen to what Florida suggested first?
Jim
Old Oct 14, 2009 | 05:47 PM
JimTranter's Avatar
JimTranter
6th Gear
Checked the resistance, ok. problem only occurs after I turn the car off. When it cools down everything is fine.
Old Oct 14, 2009 | 05:50 PM
Sweet 90's Avatar
Sweet 90
Did you check the resistance when hot? Fuel pressure OK?
Jim
Old Oct 14, 2009 | 07:22 PM
SunCr's Avatar
SunCr
The ECM uses Coolant Temperature to determine how much fuel to pulse through the injectors (the colder it is, the more fuel it gets) - so see what your Coolant Temp Sensor is showing when it's hot or better yet, what the ECM thinks that temperature is. A scan is the best way to see it, though your Digital Readout will show it. It's also a good idea to see what it is cold; ie, after it has sat overnight. It should be about the same as the outside air temp and real close to the Manifold Air Temp. Then start it up and make sure it rises to the thermostat and when that opens, it should fall back a few degrees, then rise to the threshold for fan operation. Assuming all that works, turn it off and let it sit for a minute or two; then check the signal again before you start it. Most will have risen above the temp when you turned it off - if yours is dramatically lower, I'd replace it. OR if your cold test was dramatically different from the outside air temp, spend 12 Bucks on a new one and simply plug it into the harness - if that shows the correct temp, R & R the old one.
Old Oct 15, 2009 | 07:50 AM
bangbgC6's Avatar
bangbgC6
Good luck with the problem. Repair by commitee makes for great threads.
Spend carefully until you get it diagnosed accurately.
Old Oct 20, 2009 | 11:33 AM
RON NARDONE's Avatar
RON NARDONE
had the same problem turned out to be a bad plug in contact at the fuel pump. try this while your cranking have someone push down on the rear end of the car or take a rubber mallet and give the tires a good whack in other words you have to jolt the car so the plug contact makes contact.when chevy gave me back the old fuel pum the contacts were actually black with carbon good luck
Old Oct 23, 2009 | 09:04 PM
4corvettes's Avatar
4corvettes
Have you discovered the problem yet? I am new to the forum and I'm sorry to jump on here, but, I'm having a very similar problem with my '92. If you don't mind, when you figure this out, can you let us know? Thanks a lot and Good Luck!
Sounds like it is definitely electrical since the higher temps affect the ignition. When it cools down, everything works as advertised, right?
Old Oct 23, 2009 | 09:17 PM
CorvetteMike2024's Avatar
CorvetteMike2024
Corvette Enthusiast
Default vette
Floridamale is dead on with whats wrong with your car. A bad ECM throws a code. Any codes? A leaky injector will flood your engine.
Good luck
Corvette Mike
Old Oct 24, 2009 | 07:19 PM
jfb's Avatar
jfb
Put a fuel pressure gauge on the shrader valve at the end of the right fuel rail and with the engine hot, shut off the engine and see if the fuel pressure holds up for a long time (1/2 hr). If it falls rapidly, you have leaky injector/s causing a rich mixture and poor idle and black fuel rich smelling exhaust. Injectors don't last forever. Ohmeter tests will only find gross injector coil failures. A turn to turn short in an injector coil cannot be found with an ohmeter but can easily be found with an impedance bridge, which you don't find in auto shops or stores. Your symptoms are correct for leaky injectors.
Old Oct 24, 2009 | 08:11 PM
desertmike1's Avatar
desertmike1
Just for the heck of it check for evidence of fuel in the vacuum hose connected to the fuel pressure regulator.
To problem restarting
