How to calculate engine torque
Old Oct 15, 2009 | 11:25 AM
Trebor's Avatar
Trebor
Default How to calculate engine torque
I had my '96 LT4 dynoed yesterday (see thread in tech section) but I have a question. The Rear wheel torque was 310.84 the rwhp was 303.28. I was told to divide the rwhp by .85 to find the flywheel horsepower (356.8). Do I do the same thing with the torque number of 310.84? The spec on the LT4 states it makes 340 foot lbs at 4500 rpms.
Thanks,
Bob
Old Oct 15, 2009 | 07:08 PM
jrzvette's Avatar
jrzvette
From: The reason time exists is so everything doesn't happen at once
Generally the rear wheel hp is 80 - 85% of the flywheel. The only sure way to know is to pull the engine and run it on an engine dyno. Remember, on a dyno torque is measured, horsepower is calculated. Don't really think this is necessary; rwhp (and torque) is what you're putting to the ground not the flywheel numbers.
Saw your videos - sounds great. Are you running the stock exhaust?
Oh, BTW, the divisor is .85 not 8.5.
Old Oct 15, 2009 | 10:07 PM
Trebor's Avatar
Trebor
Thanks for the input. Yes the car is 100% stock except for the air filter. I never had a car dynoed before. Standing next to the car as it was on the dyno reaching 6500 rpms really did sound very impressive and powerful. I wished I had asked them to look at the mph to see how fast the wheels were spinnning. I know I will never drive the car that fast.
trebor
Old Oct 15, 2009 | 11:03 PM
856SPEED's Avatar
856SPEED
typically a manual transmission equipped vehicle (which you have since it is an LT4) will lose 15-18% h/p through the drive train (rwhp measure); this will give you an estimate of your FW h/p.....
Old Oct 15, 2009 | 11:12 PM
MK 82's Avatar
MK 82
It is divide by 0.85.
Originally Posted by Trebor
I had my '96 LT4 dynoed yesterday (see thread in tech section) but I have a question. The Rear wheel torque was 310.84 the rwhp was 303.28. I was told to divide the rwhp by 8.5 to find the flywheel horsepower (356.8). Do I do the same thing with the torque number of 310.84? The spec on the LT4 states it makes 340 foot lbs at 4500 rpms.
Thanks,
Bob
Old Oct 15, 2009 | 11:26 PM
Mojave's Avatar
Mojave
He ran on a Dynojet, which actually measures power and calculates the torque. An eddy current dyno, like a Mustang dyno, measure the torque and calculates the power.
http://www.mazdas247.com/forum/showt...hp?t=123629978
For a Dynojet, I think 15-18% losses is too high, that would put his torque between 364 and 378, which is too high for a stock LT4 (and his dynoed very close to a lot of other LT4's on Dynojets). Using a 10% loss, it comes to 344 ft/lbs, which is right with the factory rating.
If these were Mustang dyno (or other eddy current dyno), I think the 15% would be much more applicable.
Old Oct 16, 2009 | 12:18 AM
jrzvette's Avatar
jrzvette
There's a mistake in that article. In one paragraph it states
Tq = HP x 5252/RPM
Two paragraphs later it states
HP = Tq x 5252/RPM
both statements can't be correct. From the first formula (Tq = HP x 5252/rpm) it follows that HP = Tq x RPM/5252.
Old Oct 16, 2009 | 12:24 AM
Mojave's Avatar
Mojave
Tq = HP x 5252/RPM
HP = Tq x 5252/RPM
The first formula is correct, and your formula is correct.
http://www.revsearch.com/dynamometer...orsepower.html
But either way, not all dynos work the same way.
Old Oct 16, 2009 | 12:26 AM
jrzvette's Avatar
jrzvette
understood
To How to calculate engine torque
