code 42
Old Oct 22, 2009 | 06:22 PM
kimmer's Avatar
kimmer
C4 of the Year Finalist
Default code 42
car started dying got a code 42 now what should I be checking and how?
Old Oct 22, 2009 | 07:19 PM
kimmer's Avatar
kimmer
come on guys, a little help pleaseee
Old Oct 22, 2009 | 07:46 PM
jim_hewett's Avatar
jim_hewett
Default Code 42
Electronic spark timing (EST) circuit. Check wiring and connectors betw
ignition module and ECM. Replace the ignition module. Replace the ECM.
Cheers
Check 6
Old Oct 23, 2009 | 08:35 AM
jeffp1167's Avatar
jeffp1167
I think the magnetic pickup coil will trigger this code as well. but usually when it goes the engine misfires and drops fire to cylinders.
Old Aug 4, 2025 | 08:59 PM
John@scc's Avatar
John@scc
Did you find a solution to your problem? I have a code 42 also.
Old Aug 4, 2025 | 11:46 PM
IHBD's Avatar
IHBD
Pro Mechanic
What year, which engine?
On an L98, Code 42 will set when the Set Timing connector is disconnected to use a timing light to check the timing. When the connector is reconnected, the Service Engine Soon light goes off with the next key cycle. The Code 42 remains for 50 Ignition cycles, but doesn't affect the way the engine runs before it self-clears. << This is probably the most likely scenario for a Code 42 on L98s.
A Code 42 on an LT1 is very likely to be the Ignition Control Module. If you have an LT1 that cranks but does not fire, and there is a Code 42 but no Code 16, it is highly likely that the ICM has failed.
The LT5 also has a Code 42.
Need to know the engine, and perhaps some details, like does it run, or did you just happen to find Code 42 in memory in an L98 after the smog tech checked the timing?
Old Aug 5, 2025 | 12:04 AM
RustyDuster's Avatar
RustyDuster
I sure hope he did, the thread is 16 years old. I wish folks would come back and say how they solved the problem in the archived threads. Wonder if these guys are still around?
Old Aug 5, 2025 | 06:14 AM
John@scc's Avatar
John@scc
I have a 1982 Crossfire. There wasn't any work being done to the car when the Check Engine light came on... It just appeared. Car still starts and seems to still run fine. I noticed it first came on after driving a few blocks then went off. But back on now. I'll take it out again today. I've had ignition modules go bad in other cars and they don't start. Not the case in this instance.
Thanks for the reply.
Old Aug 5, 2025 | 06:16 AM
John@scc's Avatar
John@scc
That would be nice and very helpful.
To code 42
