car won't start!
Old Oct 24, 2009 | 02:49 PM
agentvq's Avatar
agentvq
4th Gear
Default car won't start!
I removed the fuse to stop the fuel pressure to change the water pump, put back together now car won't start. Do I have to energize the fuel pump? if so, how do you do it. Anyone done this before?.
Old Oct 24, 2009 | 04:00 PM
shiyfire's Avatar
shiyfire
Can you hear the fuel pump run when you cycle the key?Just make sure the fuse is good and goes back in the same slot
Old Oct 24, 2009 | 04:18 PM
agentvq's Avatar
agentvq
4th Gear
The fuse is good, I do not hear the pump run.
Old Oct 24, 2009 | 04:35 PM
shiyfire's Avatar
shiyfire
There should be a test wire under the brake master cyl. if you have a test light.should be hot when you cycle the key.
Old Oct 24, 2009 | 06:26 PM
agentvq's Avatar
agentvq
4th Gear
Thanks.
Old Oct 24, 2009 | 06:56 PM
jfb's Avatar
jfb
Is there some reason why you don't want to tell us what year Corvette you have?
Old Oct 24, 2009 | 10:18 PM
agentvq's Avatar
agentvq
4th Gear
The car is a 1989 corvette with an L98 engine.
Old Oct 24, 2009 | 11:54 PM
jfb's Avatar
jfb
The fuel pump gets energized when you turn on the ign sw to run, it runs for 2 seconds and will be turned on if the ECM receives ign pulses from the distributor and/or if the oil pressure switch gets 4 psi on it. The ECM turns on the fuel pump relay and the oil pressure switch bypasses the fuel pump relay. You could measure the voltage on the fuel pump fuse while you crank the engine and see if you get 12v and for how long, try both ends of the FP fuse. If you get 12v but no fuel pump noise, then you have to check the fuel pump wiring and if ok, the fuel pump is suspect. If no 12v on the FP fuse, then you have to find out why. You will need to determine if the ECM is getting power and if the ECM receives distributor pulses during cranking.
To car won't start!
