Underhood lights not working
Old Oct 25, 2009 | 06:47 PM
Jbyrd43's Avatar
Jbyrd43
Default Underhood lights not working
My underhood lights aren't working. I figured it was the bulbs so i bought 2 and nothing. I can't find a switch for them. What fuse is it? Any other ideas why they woudn't work?
Old Oct 25, 2009 | 06:51 PM
msslp04's Avatar
msslp04
St. Jude Donor '11,'14
The underhood lights have a mercury switch that turn the lights on when the hood is lifted. You may want to check that also.
Kevin
Old Oct 25, 2009 | 07:03 PM
Jbyrd43's Avatar
Jbyrd43
Where is that switch at?
Old Oct 25, 2009 | 07:13 PM
floridamale's Avatar
floridamale
It's located at the botom of the lights when the hood is open. I have a switch that I use to turn mine on or off
Old Oct 25, 2009 | 07:24 PM
c4cruiser's Avatar
c4cruiser
It could be that the wires for the lights are not connected. Look in the headlamp wells next to the cornering lamp housings. The harness from each of the underhood lamps travel downward to the housings and there is a 2-wire Weatherpak connector near the housings. Check to see if they have been disconnected there. That's pretty common to do if the hood is left up for extended periods.
The mercury switches are at the bottom of the clip that holds the bulbs. For the most part these don't fail but somebody could have removed them.
Old Oct 25, 2009 | 07:48 PM
Frizlefrak's Avatar
Frizlefrak
What the guys above said.
There should be power to the housings at all times. The mercury switches are inside next to the bulbs. When the hood tilts, the mercury moves and completes the circuit. Test first for 12V to the housing. If no power there, check down in the front fender wells and see if someone has unplugged them. I leave mine unplugged when working on the car for more than a few minutes so they don't drain the battery. A previous owner may have just unplugged them.
Old Oct 25, 2009 | 08:19 PM
Jbyrd43's Avatar
Jbyrd43
They aren't disconnected and im gonna check the switch in the morning
Old Oct 25, 2009 | 09:21 PM
STL94LT1's Avatar
STL94LT1
I'm not sure about your 91, but on my 94 there is a fuse for the underhood lights in the engine compartment by the left cornering lamp.
Old Oct 25, 2009 | 09:23 PM
c4cruiser's Avatar
c4cruiser
Do your interior lights work??
To Underhood lights not working
