Passive Keyless entry
Old Feb 25, 2002 | 09:49 PM
Bill Hewitt's Avatar
Bill Hewitt
2nd Gear
Default Passive Keyless entry
I have a 94 with Passive Keyless entry, somehow I think I have blown a fuse, it is not the fuse in the passanger side fuse block, I noticed that the PKE icon on the computer screen no longer lights up when ignition is on, wondering if anybody knows if there is another fuse, if so where is it?
Old Feb 25, 2002 | 10:44 PM
Dualnic's Avatar
Dualnic
Default Re: Passive Keyless entry (Bill Hewitt)
Welcome to the forum Bill..... since u did not mention if the "PKE" was active or not.....first make sure u did not turn off the "Passive" function...by mistake....hold the "Door" button in range and wait till u hear the doors cycle....also if u have the "PKE" turned "OFF" only the passenger door will open with the "Door" button depressed.
I sent u some scanned pages from the Helms..on the 94 PKE SystemOperation/Programming......unless your isp has a xfer limit crossing fingers :) .
[Modified by Dualnic, 8:46 PM 2/25/2002]
Old Feb 25, 2002 | 11:26 PM
R23HTC's Avatar
R23HTC
Default Re: Passive Keyless entry (Dualnic)
What he said. You probably just shut it off by accident.
Old Feb 26, 2002 | 12:13 AM
TVS VETTE's Avatar
TVS VETTE
What Dualnic said is right. I am a fairly new member also, and had similar problems withe the PKE. He knows what he is talking about. He sent me the Helms info also and it worked. My 94 still has a bad ground in ;the drivers door wiring. You have to open and close the pass door to engage the alarm.. I will tackle this job in the spring. Good luck :seeya :seeya
Old Feb 26, 2002 | 12:33 AM
Bill Hewitt
2nd Gear
Default Re: Passive Keyless entry (TVS VETTE)
Hey TVS VETTE ...your right Dualnick knows exactly what he is talking about, I went out and did what he said and ....there it was...working like a charm...guess I had turned the thing off without knowing...all is well now....hey you said you were new to the forum,,,boy - o - boy what a great service for us guys struggling along with a screw driver in hand.....Thanks for the reply...Bill
To Passive Keyless entry
