Build sheet present !
Oct 30, 2009 | 02:12 PM
But I cannot get it to come down. How tight is this thing in there and what is the best way to get it out?
Oct 30, 2009 | 02:42 PM
Quote:
Originally Posted by
Idoktr
We need a little more info than that. Are you referring to the build sheet that is up on top of the fuel tank? If so, it's strapped in.
Oct 30, 2009 | 02:55 PM
From: Why are there squished peanut butter cups in my underware?
Oct 30, 2009 | 02:58 PM
St. Jude Donor '09 thru '25
Loosen the straps, otherwise you'll rip it to shreads. Or leave it and just order one from the NCM.
Oct 30, 2009 | 03:42 PM
yup, that's it
jimg's'93
how do you loosen the straps to get it out?
Oct 30, 2009 | 04:11 PM
Idoktr
There are two straps, one on each side, with a nut. Find the one that is holding down the strap your sheet is under, spray some PB Blaster or like substance on nut and threads to break it loose (needless to say, don't use heat
). May need to soak a day or two with a another application. Go easy, you don't want to break it off. Jockey strap to get some slack, pull out build sheet and then retighten to 40 in lbs.
Oct 30, 2009 | 06:13 PM
CI 3-4, 8-9-10 Veteran
St. Jude Donor '06-'08-'10
Idoktr
....what is the best way to get it out?
Order it from the NCM.
Oct 30, 2009 | 09:35 PM
From: levittown pa. usa Even a bad day with my `Vette, is better than a good day at work
St. Jude Donor '10
Blue 92
Thats the best way
Oct 30, 2009 | 09:37 PM
Would the build sheet up on the tank even be legible after all these years? I'd think not.
Oct 30, 2009 | 09:58 PM
jimg's'93
Yes.
