Broken Radiator Drain Plug?
what I was doing, but managed to get a pair of pliers on the drain plug.
Pliers!? Pliers!? That plastic piece-o-crap kept breaking off. Who's design was that? I don't think it budged though. I ended up draining from the
bottom radiator hose. BTW, I'm thinking that draining some of the coolant would allow me to disconnect what seems like a 3/4" heater hose that was dripping down on the wires & opti
. After pulling thathose it seemed like a couple o' pints of coolant came gushing out all over the rags I had in place. Bottom line is I didn't finish what I started
and have go at it again. Because I was concerned about the Opti, I
filled the system so I take it for a spin to see if all was well. And it was.
Question: Is there a TOOL for removing the radiator "drain plug"? If not,
how is this done. I'm sure most of the plugs have seized up over time.
Thanks again.
Just did mine yesterday. No problems. If you get it out get a new plug.
Jim
