Shocks
Old Nov 9, 2009 | 11:49 AM
denburke's Avatar
denburke
6th Gear
Default Shocks
I am thinking of changing the shocks on my 1990 corvette. It is now equipped with the FX3 air control shocks. Can I replace them with a less expensive kind of shock that will provide a nice ride for less? I am not to concerned with the original equipment for resale, since other things have already been changed. Any suggestions are welcome.
Thank you Dennis
Old Nov 9, 2009 | 02:56 PM
Larry/car's Avatar
Larry/car
I wish my C4 had the FX3 system. I have the heavy duty suspension on my 1995 and the ride is firm, first generation runflat tires don't help either. I traded a 1990 with the FX3 option and really liked it. The suspension adjusts to the road differently/faster with the electronic system than just standard shocks. The FX3 system is an early version of the now available F55.
Old Nov 9, 2009 | 04:13 PM
denburke's Avatar
denburke
6th Gear
Default denburke
Thanks for your note Larry, but that didn't answer my question. I need new shocks and I want to replace them with less expensive ones.
I need advise from someone that has changed them without using the original air control ones.
Old Nov 9, 2009 | 04:36 PM
dpd3672's Avatar
dpd3672
I think if you use the non-OEM shocks it'll trigger an error code, "Service Ride Control" on the dash. Other than that, I don't think there are issues.
I think you can get the original shocks rebuilt, though, for about the same price as a new set.
Dave
Old Nov 10, 2009 | 12:33 PM
denburke's Avatar
denburke
6th Gear
Default shocks
Thank's Dave, I never thought of the error code. I had that code for a while and someone before me unplugged the wire for that. It has since been replugged and I don't get any error. My garage said that the shocks are leaking, so I better replace them. Again thank you
Old Nov 10, 2009 | 02:34 PM
BrianCunningham's Avatar
BrianCunningham
From: Boston, Dallas, Detroit, SoCal, back to Boston MA
You can get your stock shocks rebuilt, or just get new ones.
No need to buy a new controller.
Old Nov 10, 2009 | 03:20 PM
rocco16's Avatar
rocco16
From: SCMR Rat Pack'r Charter Member..Great Bend KS
Nice ride and C4 do not belong in the same sentence.
....and the shocks have nothing to do with it.
Just bolt on a set of Bilsteins or Konis and be done with it forever.
Larry
______________
not easily impressed....
Old Nov 10, 2009 | 03:25 PM
denburke's Avatar
denburke
6th Gear
That's what I was thinking about, but like one other guy said I may get an error code on my computer. I don't know if the computer is hooked into the air ride control or not, I will have to do some checking. I appreciate the opinion, thanks
Old Nov 10, 2009 | 03:37 PM
Goldcylon's Avatar
Goldcylon
If you pull the FX-3s you can always pull the bulb behind the DIC for the light. Or use a piece of black electrical tape. GC
Old Nov 10, 2009 | 06:08 PM
denburke's Avatar
denburke
6th Gear
More than one way to skin a cat> Thanks
Old Nov 10, 2009 | 10:43 PM
jdr650920's Avatar
jdr650920
Cruising
new member Have 93 vette with ride control. Erro message of "service ride control". From what's been said more than likely leaking shocks?? JDR
To Shocks
