Brake Work Needed
I took my '89 vert to Big "O" in KY and they charged $60.00 per wheel to turn rotors and install new pads.
Just make sure they are carefull lifting. Rocker pannels and fuel lines are easy targets.
DM
If you don't have a club or friends available, get one of those books on how to fix up a Corvette with photos and you can probably get the whole thing done in an hour or so...it's only a little harder than changing your tire or the oil on your car.
You'll also have the opportunity to clean up the whole area, and you can paint your calipers, if that's your thing, while you've got access...it's a great cosmetic touch, cheap/easy to do, and makes cleaning up the wheelwells much easier.
It's also pretty hard to screw up...just make sure the pads are on the right way (my neighbor just did brakes on his car and put one of the pads on backwards, D'OH)...go slowly and be careful.
The first wheel you do will take a few minutes to figure out. The next 3 are 10 minutes jobs each, at most. My personal preference has always been to use new rotors, rather than having the old ones turned...it's maybe a bit wasteful, but for me, it's cheap peace of mind.
Your savings, depending on where you were going to take the car and where you buy your components should be in the hundreds of dollars...now take the money you save and use it to fix something else on the car, detail it, or take the wife/gf/so out to dinner!
Dave
