Differential fluid, how often?
Old Nov 17, 2009 | 06:57 PM
Goldenboyws6's Avatar
Goldenboyws6
Default Differential fluid, how often?
How often do you replace it? Thanks
Old Nov 17, 2009 | 07:07 PM
RedVette84's Avatar
RedVette84
There should be a recommended fluid change chart in the owners manual. But since we don't usually put the mileage on our cars like others you might have to use time as a reason to change. I don't believe gear oil is as hydroscopic as hydrauilic fluids so it should be good for a longer time. When I buy a used vette I do change the fluids as a precaution unless there are good records of fluid changes. I don't usually change the diff fluid for 4 or 5 years myself more if mileage is higher. I think mu SUV recommends 30k but unless it's been in dirty or very wet conditions I usually go more. But don't forget the GM diff additive when you change it.
