Seats interchange?
Old Nov 22, 2009 | 12:29 PM
VinceC4's Avatar
VinceC4
Default Seats interchange?
My drivers seat is really starting to show signs of wear..the passenger seat is in excellent condition, can I switch the seats?..they sure look the same. I would hate to go through the trouble of unbolting them, only to find they don't interchange.
Old Nov 22, 2009 | 12:47 PM
floridamale's Avatar
floridamale
Not sure what year you have, but it is ok to just switch the cushions from side to side if you have standard seats. If you switch the entire seat frame the controls will be wrong. Also if you have sport seats they will be wrong. lots of us change the lower cushion because of wear on the bolster.
Old Nov 22, 2009 | 01:25 PM
VinceC4's Avatar
VinceC4
I have a 95 with sport seats, I didnt think about the controls...good thinking on your part.
Old Nov 22, 2009 | 02:18 PM
pkazsr's Avatar
pkazsr
Cruise-In X Veteran
St. Jude Donor '09
My 88 Sport Seats are identical and can be switched from side to side. The controls are the same and in the same place.
Old Nov 22, 2009 | 02:25 PM
floridamale
If you have sport seats when you switch the cushions the controls go to the opposite sides, outside becomes inside and inside becomes outside
Old Nov 22, 2009 | 03:11 PM
electricfish's Avatar
electricfish
Default seat exchange
I swapped my cushions (92 vert, std seats) and it worked fine. The spring holding the back in place are kind of hard to release but feel around in there and it becomes obvious what needs to move.
Old Nov 22, 2009 | 04:06 PM
pologreen1's Avatar
pologreen1
Yup the PO of my car, always rode alone, and the driver seat was starting to show wear, do he swapped them before it got noticeable.
My driver seat is my passenger seat now.
Old Nov 22, 2009 | 07:15 PM
Mr. Peabody's Avatar
Mr. Peabody
C4 of Year Finalist (appearance mods) 2019
Vince since you have a 95 with the late model sport seats like I do you can do one of two things.
First the easiest by far is to just unmount the seat cushion (there is a small clip on the front of the underside of the seat cushion) and just swap them from driver to passenger side. Once you unlock the clip you simply pull the cushion out from the front. There is nothing on the rear holding the cushion in. They are identicle and you cannot tell one from the other.
Second because you have the late model sport seats the "controls" are not on the seat itself but on the center console so swaping the entire seat frame from one side to the other is not as big a deal. Your car has only one air pump for both the driver and passenger seat and it is under the passenger seat. The air flows from the pump to each seat via a "T" fitting to dual air manifolds. If you are going to swap seat frames from side to side you want to first remove the seat cushions anyway so that you can carefully disconnect the air tubes running into each seat as well as the electrical connector. Be careful doing this. The air manifolds are plastic and are going to be brittle .... you don;t want to snap any of the nipples off of the manifold.
Old Nov 22, 2009 | 07:18 PM
floridamale
Great info from some one who has done them on your model year
Old Nov 22, 2009 | 11:22 PM
dogfish246's Avatar
dogfish246
Is there a way to take the back part of the seat off and not the frame? I know the bottom part comes off easily with just the metal clip thing, but is there an easy way to get the other part of the seat off?
Old Nov 23, 2009 | 05:13 AM
VinceC4's Avatar
VinceC4
You hit it right on the head, the controls are in the center console, thanks for your help
To Seats interchange?
