Automatic trans shift points
Old Nov 23, 2009 | 05:59 PM
stealthy vette's Avatar
stealthy vette
Default Automatic trans shift points
Hi, what are the stock shift points for a 92 vette?
At wot I get 3800 in 1st and around 5000 for 2nd
Is this accurate? Is there an easy way to adjust?
Old Nov 24, 2009 | 07:19 AM
stealthy vette
The shift points are not controlled by the computer correct?
Nobody knows?
Old Nov 24, 2009 | 07:43 AM
Pete K's Avatar
Pete K
Nobody knows?
This question has been asked and answered dozens of times recently, and much info can be found using the search feature.
The governor controls shifting. It works as a function of rpm and line pressure. Line pressure (assuming a healthy trans) is sent to the governor via tv pressure. TV is throttle valve.
The governor is not adjustable. To custom tune it, you must swap weights and springs.
However, I dont recommend this as you 3800 rpm wot 1-2 suggests low line pressure, likely as a result of a misadjusted tv cable.
92 and 93 are difficult to adjust compared to earlier years. Consult the shop manual for the procedure, and follow it to the letter.
If you dont own a shop manual, the search feature will bring it up, as it has been scanned and posted many, many, times.
I hope this is helpful.
Old Nov 24, 2009 | 07:47 AM
stealthy vette
Thanks for the reply, I searched and got mixed results from the different years 4l60 vs 4l60e.
Would this be helpful if I want to adjust shiftpoints?
http://www.eautoworks.com/product-BampM-182127.htm
Old Nov 24, 2009 | 08:34 AM
Pete K's Avatar
Pete K
Nothing in 1992 received a 4l60E, so you can ignore those search results.
The kit listed above is a shift kit, and does not affect shift points.
After you solve your problem, this:
http://www.eautoworks.com/product-BampM-181910.htm
can be used to custom tailor your shift points, if you desire.
To Automatic trans shift points
