Quick rearend/leaf spring question
Old Nov 25, 2009 | 01:15 PM
Alan777's Avatar
Alan777
Default Quick rearend/leaf spring question
I've got a rearend out of an 88 4+3 sitting in my driveway that I'm taking apart. I got all the control arms, shocks, etc out, but Im curious about how to take the leaf spring out?
The problem is that because on the weight of the rear end rests on the spring, It doesn't compress. Is it still safe to remove the pin and castle nut on the end, and slowly unthread it? I'm not exactly sure how much spring this leaf spring has.
Old Nov 25, 2009 | 05:21 PM
rodj's Avatar
rodj
You need some means of compressing and holding the spring while removing the nut.
Old Nov 25, 2009 | 07:32 PM
PLRX's Avatar
PLRX
Co-winner 2020 C4 of the Year - Modified
2017 C4 of Year
2016 C7 of Year Finalist
St. Jude Donor '09 thru '20
For the rear spring, lift the vette at the frame and let the suspension hang.
Remove the cotter pin then the nut
Old Nov 25, 2009 | 08:54 PM
aminnich's Avatar
aminnich
But first compress the spring, or get the first aid kit out.
Old Nov 25, 2009 | 09:07 PM
Doug 87L98's Avatar
Doug 87L98
Had my rear out three times and did it this way. But it is probably safer if you compress the spring first.
Old Nov 25, 2009 | 09:12 PM
rodj's Avatar
rodj
It is no longer in the car
"got a rearend out of an 88 4+3 sitting in my driveway"
To Quick rearend/leaf spring question
