Need your help
Old Nov 28, 2009 | 10:27 PM
LT4 in Hawaii's Avatar
LT4 in Hawaii
Default Need your help
I have a 96 LT-4, 6 speed. The battery was replaced about a year ago. I only drive the car a few times a month. But when I do, I take it out and run it for about an hour or so on the highway. Recent Problem: when I turn the key, nothing happens. I have power for head lights, radio etc. But there is no clicking sound......nothing at all. What can it be?
Old Nov 28, 2009 | 10:38 PM
TheDudeMatt's Avatar
TheDudeMatt
Im no mechanic but if it doesnt click and you have power its your starter.
If its not that check the alarm system.
This may not be the case but it happened to me.. The security system was preventing me from starting the car.
my last suggestion would be to get a multi meter and check the power comming out of the battery.. I think its 14v( or amps not sure which ) to start the car.
Old Nov 29, 2009 | 08:30 AM
aminnich's Avatar
aminnich
Actually it sounds like a VATS issue. Is the security light staying on when you are trying to start it?
Old Nov 29, 2009 | 10:08 AM
joe3906's Avatar
joe3906
Go underneath the car, rap the starter with a hammer a couple of times, if it starts, your starter is no good.
Old Nov 29, 2009 | 01:40 PM
RedVette84's Avatar
RedVette84
Could be a bad starter drawing too many amps to turn over.
Old Nov 29, 2009 | 01:48 PM
ZR-71's Avatar
ZR-71
St. Jude Donor '15
Could be the clutch switch too
In a pinch if you are away from home, do a push start and pop the clutch
Old Dec 14, 2010 | 10:36 AM
SouthernSon's Avatar
SouthernSon
Fuses by the battery could also cause the same thing. There are 2 gang holders by the battery. One is very obvious by the inside wheel well, the one you want is farther back and sort of hidden. It is a small black holder with about a half dozen maxi fuses. There are two 60 amp fuses that relate to ign. If they are blown, the symptoms you describe result. Keep chasing down the different causes and I know you will find it.
Old Dec 14, 2010 | 12:41 PM
F40's Avatar
F40
Old Dec 14, 2010 | 02:34 PM
Sweet 90's Avatar
Sweet 90
Well seeing this thread is over a year old, let's hope the OP has his problem fixed by now
Old Dec 14, 2010 | 05:19 PM
kimmer's Avatar
kimmer
C4 of the Year Finalist
Damm, I was just about to ask him to send me a ticket and I would come look at it.
Old Dec 14, 2010 | 07:54 PM
LT5corsa's Avatar
LT5corsa
1994 Admiral Blue ZZZZZR1
Northeast Events Coordinator
Old Dec 14, 2010 | 08:08 PM
96 Vette CE's Avatar
96 Vette CE
Banned Loser
From: They say you learn from your mistakes, I must be a genius
2017 Corvette of the Year
2016 C4 of Year Finalist
Creator of the "Original" whining and crying thread
St. Jude Donor '14-'15-'16-'17
I'll never understand why members other than the original OP would resurrect a thread like this.
Old Dec 15, 2010 | 09:43 AM
SouthernSon
I must have really been late night scrounging around in threads. Please pardon......
Old Dec 15, 2010 | 03:33 PM
socalman's Avatar
socalman
St. Jude Donor '10
WTH are you doing scrounging around page 32?
Old Dec 15, 2010 | 06:39 PM
desertmike1's Avatar
desertmike1
Well, now that it's been brought back to the "top"...OP, what was your fix?
Old Dec 15, 2010 | 06:57 PM
steverichmond's Avatar
steverichmond
This thread did raise a question in my mind. If it were a VATS issue would a rolling start work?
Old Dec 15, 2010 | 07:49 PM
RollaMo-LT4's Avatar
RollaMo-LT4
St. Jude 15 Year Donor
2021 C4 of the Year - Unmodified Finalist
St. Jude Donor '10 thru '25
No.
To Need your help
Old Dec 15, 2010 | 08:51 PM
steverichmond
I didn't think so. Not sure why I asked, mine is an automatic. Just curious I guess.
Old Dec 16, 2010 | 08:29 AM
SouthernSon
I think I was doing a search for radio wiring in threads. I am not sure. The good information found in the archives makes them worth keeping and searching from time to time, don't cha think?
Old Dec 16, 2010 | 10:28 AM
Sweet 90's Avatar
Sweet 90
Even a 10 year member isn't above our rath
