Why are we always damned?
Old Nov 29, 2009 | 04:42 PM
Flame Red's Avatar
Flame Red
Default Why are we always damned?
Well I almost gave up. Just spent 6 hours changing my plugs and wires on my vert. Should have taken 2 - I know. Was just about ready to give up.
Problem (of course) started on the first plug #1. Removed the splash panel and did all the normal tricks of universals, extensions and even the hose. NOTHING could make that plug thread in! After two hours, I managed to get it. But only after I sacrificed a pint of blood. I know our engines are supposed to be red (all vettes are Red) but having the top of the plenum smeared with my blood is not what is meant.
It seemed once I had given up a pint, and and a few tools, along with a spark plug - which dropped into the abyss and then got beamed up by Scottie, the car was happy and relented and permitted me to continue. The rest went easy.
Ok, I admit I have full length headers but this is ridiculous.
Is there some ceremony we are supposed to do before normal maintenance to appease the car? I don't see one listed in the Helms manual.
Old Nov 29, 2009 | 05:04 PM
corvetteronw's Avatar
corvetteronw
Cruise-In VII Veteran
Cruise-In VIII
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16
Pay one of the skinny neighborhood kids with long arms $20 to do it for you next time. Same goes for when you need to change tail light bulbs in an 84 to 90.
Old Nov 29, 2009 | 05:18 PM
mikeb's Avatar
mikeb
2023 Corvette of the Year Finalist - Unmodified
2022 C3 of the Year Winner - Unmodified
Beer.
Lots of beer.
Old Nov 29, 2009 | 05:36 PM
RedLS1GTO's Avatar
RedLS1GTO
Just start pulling pieces off and eventually it gets easier. You don't need most of it anyway.
~25 minutes for all 8 plugs on the LT-4. I can do a water pump in ~10
Old Nov 29, 2009 | 05:44 PM
pologreen1's Avatar
pologreen1
lol /\
Old Nov 29, 2009 | 06:55 PM
RedVette84's Avatar
RedVette84
Martinis work well also. I keep a first aid kit at the ready with a tournicut if needed for the heat shield injuries.
Old Nov 29, 2009 | 07:09 PM
Jon Hekking's Avatar
Jon Hekking
As a loyal employee of MAC Tools, I believe there is the right tool for every job........... as long as that job isn't on a Vette
I have every tool known to mankind, what I don't have I get one as a sample to try out. They work on every car I own, almost. I can use the same tool on my Jeep and my Chevy truck (yes, I'm leaving my Taurus out of this one) and it's fine but will cease to operate properly on the Vette.
Old Nov 29, 2009 | 07:17 PM
Frogr1701's Avatar
Frogr1701
"Well, If I gotta be damned you know I wanna be damned..."
I found spark plugs to be one of the most annoying jobs (after pulling an exhaust manifold)...trying to get the right alignment...limited space for your hand let alone fingers...wrench is either too short or too long...
Love the engineering, hate the assembly.
Old Nov 29, 2009 | 07:31 PM
RedLS1GTO's Avatar
RedLS1GTO
It could be worse... could be a 4th gen F-body. If it needs a tune-up and new plugs, you'd be better off to just total it. I tried that once. NEVER again.
Old Nov 29, 2009 | 07:34 PM
BigTexas's Avatar
BigTexas
That picture of that camaro makes me sick. How do they expect a person to do maintenance on that thing?
Old Nov 29, 2009 | 07:46 PM
aboatguy's Avatar
aboatguy
Can you get some of the plugs from underneath the car????
That's what I used to do on my LT1 Vert when it still had factory manifolds. I'd do the rear Passenger side plug backwards I found that facing away from the car and reaching backwards I could get my hand on the plug
Mike
Old Nov 29, 2009 | 07:50 PM
redrose's Avatar
redrose
Default ol' time magic
i slip a STRAIGHT piece of 3/8'' fuel hose (old style low pressure hose) abt 3'' long onto the spark plug end for finger grip to start em in...don't have any 'theories' why, but the spark plugs find the hole and thread in, as if some 'magic hand' is helping...works fer me, sober or not
Old Nov 29, 2009 | 08:27 PM
ps374's Avatar
ps374
The newer C4s are harder right? My 84 looks like a 30 minute job at best. Last owner just changed them.
Old Nov 29, 2009 | 08:50 PM
Klondike's Avatar
Klondike
SHOW OFF! I looked like the living dead when I did my LT4, I lost so much blood. I looked like a rookie oyster opener!
Old Nov 29, 2009 | 09:03 PM
PLRX's Avatar
PLRX
Co-winner 2020 C4 of the Year - Modified
2017 C4 of Year
2016 C7 of Year Finalist
St. Jude Donor '09 thru '20
holy Fk, I knew this Trans Am owner and he told me this was a real
PITA
I cant elaborate because I've never owned a LS F Body. Just look at that hood Remember, the 93 Camaro was designed to haul the LT engines. GM shoved the LS in 98.
Old Nov 29, 2009 | 09:05 PM
bb62's Avatar
bb62
Maybe you guys need a C4 with one of these:
Old Nov 29, 2009 | 09:06 PM
TheDudeMatt's Avatar
TheDudeMatt
Agreed i own a camaro... To change the spark plugs you practically need to pull the engine...( Exaggeration )
But seriously, you need to do some fancy work though to get around certian parts.
To Why are we always damned?
Old Nov 29, 2009 | 09:19 PM
redrose's Avatar
redrose
you unbolt the whole engine with the 'correct' service cradle under it and raise the body up,up and away...no sith
more evidence of a GM 'grey matter' problem ???
Old Nov 29, 2009 | 09:29 PM
bdw18_123's Avatar
bdw18_123
From: Prather, California -1990 ZR-1 White/Flame Red- -SOLD!!-
Yup, LT5 sparkplugs are cake to get to!
I consider myself lucky to be able to own one of the less than 6,900 (actually 6,939, but some are totaled) ZR-1's in existance. Yes, I know, they can be had fairly cheaply right now, but I don't think that will last forever.
Old Nov 29, 2009 | 09:35 PM
4CAM LT5's Avatar
4CAM LT5
St. Jude Donor '09
...Easy stuff on the LT5...!!
