Brake problems-87 Corvette
Old Dec 3, 2009 | 04:40 PM
railer75's Avatar
railer75
Default Brake problems-87 Corvette
I am having a problem with the left front brake -it seems to be binding and won't release completely-the wheel feels very hot! The caliper and bearing/hub were replaced and the system flushed and bled but that did not solve the problem- I would welcome any help- Thanks HK
Old Dec 3, 2009 | 04:46 PM
rodj's Avatar
rodj
Brake hose might have collapsed inside
RedVette84's Avatar
RedVette84
Did you check the brake hoses? Was it a rebuilt caliper also?
Old Dec 3, 2009 | 04:56 PM
railer75's Avatar
railer75
Thanks for the quick response-the caliper and hose were replaced -could it be a speed sensor or abs problem?
Old Dec 3, 2009 | 06:41 PM
c4cruiser's Avatar
c4cruiser
A VSS or the ABS "should" not be a problem. Has the ABS light come on during hard braking or just when driving?
Sometimes you get a reman caliper that was either not assembled properly (piston may be binding in the bore) or was not completely cleaned before the rebuild process.
Remove the caliper and see if you can push the piston back in the bore by using a C-clamp. If it won't move, then I would have the caliper replaced.
Old Dec 3, 2009 | 08:08 PM
railer75's Avatar
railer75
Default 87 Brakes
The ABS light has not come on at any time-I don't think that it is the caliper because when I drove it today I came back and jacked it up and the wheel would not turn by hand (the wheel and caliper felt hot)- after about 10 minutes the wheel turned freely. Thanks for your help
Old Dec 3, 2009 | 09:29 PM
Calderone's Avatar
Calderone
Old Dec 3, 2009 | 09:37 PM
Livin the Dream's Avatar
Livin the Dream
next time you take it out and come back try to turn the wheel if tight - open up the bleeder and see if it frees up the wheel . If it does something is not letting the pressure release from that line.
Old Dec 3, 2009 | 10:14 PM
railer75's Avatar
railer75
I will be away until Sun nite-(I won't be driving this car!) but on Mon I will try opening the bleeder and moving the piston w/ a clamp and I will post the results- Thanks for all the help!
Old Dec 5, 2009 | 04:31 PM
UK guy's Avatar
UK guy
let me know how you get on as i've got the same problem with my 86 !!
Old Dec 5, 2009 | 05:30 PM
Z5287's Avatar
Z5287
Yes my 87 has the same symptoms
New calipers, L and R ,both hoses ,Master, and pads
I was thinking ABS control next but I recieved a quote for the part
of 720.00
Old Dec 8, 2009 | 11:36 AM
UK guy's Avatar
UK guy
ttt
Old Dec 8, 2009 | 01:23 PM
railer75's Avatar
railer75
Was your problem on both sides or just one like mine?
Old Dec 8, 2009 | 01:47 PM
UK guy's Avatar
UK guy
just the front left !
been trying to find any threads on here about it but nothing !
its half the reason i parked mine up 5 years ago and not used it since but its coming out of the garage in the next couple of weeks and its the first thing i'm looking at but dont know where to start.
i've got hold of a new caliper and discs so i was hoping that would sort it
Old Dec 8, 2009 | 01:50 PM
UK guy's Avatar
UK guy
now thinking it could be the ABS pump ??
Old Dec 8, 2009 | 03:51 PM
railer75's Avatar
railer75
Mine is also left front-I already have new rotors and pads all around- new (rebuilt?) caliper and bearing hub on left- I hope to get some time to look into it in the next couple days and I'll let you know!
Old Dec 9, 2009 | 03:44 PM
railer75's Avatar
railer75
I checked the front brakes today after taking it out for a 10 min drive-I jacked it up and found both front wheels were hot-and the and the brakes were locked the wheels did not turn! I cracked the bleeder valves to release pressure and that freed up the wheels-so I don't think that the calipers are the problem- my next move will be to check the brake lines between the master cyl and the front wheels to see if there is a blockage-if not I will change the master cyl - any other ideas?
To Brake problems-87 Corvette
Old Dec 9, 2009 | 03:54 PM
UK guy's Avatar
UK guy
well not having seen my car for the last few weeks not sure whats next but does the brake line run to the abs pump ? if not then its got to be the master cylinder i would think.
OMG a new cylinder from ecklers is $230 !! i'll be looking round for a rebuild kit if they are out there !!!!!!
Old Jan 28, 2010 | 02:38 PM
LMDNC5's Avatar
LMDNC5
St. Jude Donor '11-'12-'13-'14-'15,'19
This very well be the ABS hydrolic assembly. They use a one way valve and it could be holding back pressure
Old Jan 28, 2010 | 06:12 PM
railer75's Avatar
railer75
I found a brand new master cyl on Ebay for $143- the seller is a chevy dealer from Fla- I think his nae is number1gmparts-
