priority list for 91
Old Dec 6, 2009 | 12:26 AM
spacerust's Avatar
spacerust
Cruising
Default priority list for 91
ok i am getting ready to start changing things on my 91. until now i have just kept it with regular maintenance. now i have noticed that she is burning a little more oil than before. time for overhaul? if so, straight rebuild or mod. use as a daily driver. if i were to do that, tranny too? doesn't slip but was figuring if i do the motor and tranny it would be a good foundation to go from. been reading about the suspension too. but want to start with majors first. it's a stock 91 and it's works fine but am starting to notice performance is sliding. suggestions?
Old Dec 6, 2009 | 12:44 AM
l98tpi's Avatar
l98tpi
Max G’s
Why do you feel it needs an overhaul? How many miles? Do you have oil leaks anywhere on the engine, like at the oil dipstick tube?
Old Dec 6, 2009 | 09:22 AM
RedVette84's Avatar
RedVette84
What type of gas are you using ? It's always good to run a good fuel treatment through every oil change. Also the injectors could be dirty or need replacing.
Old Dec 7, 2009 | 12:36 AM
spacerust's Avatar
spacerust
Cruising
what would be the best way to determine if it is the injectors?
Old Dec 7, 2009 | 09:23 PM
l98tpi's Avatar
l98tpi
Max G’s
I would check your fuel pressure first. Also, if you are burning oil, you probably have worn rings and you would be loosing compression. Maybe you should take it to a reputable garage in your area and have them look at it and give you a good diagnosis.
Old Dec 8, 2009 | 01:08 AM
f451degrees's Avatar
f451degrees
The stock injectors in your 91 may be damaged by an injector cleaning fuel additive, so be careful.
My 91 has 130k on it and other than a leaky calve cover gasket, that I can't quit driving it long enough to fix, still goes enough to make me smile every time I bust the tires loose.
To priority list for 91
