85 lost overdrive
Old Dec 7, 2009 | 03:57 PM
Blackhole's Avatar
Blackhole
Default 85 lost overdrive
Finally got mine out of the garage and on the loop and had no overdrive. Since I had the throttle body off recently for the coolant bypass mod,( I remove the nipples and plugged em) I thought the TVS was out of adjustment so I reset it according the the FSM. Still no 4 th. gear, all other gears normal. I'm not sure were to go now, fluid is full and clean, although I have had a leak since I got the car 5 years ago. Maybe pull and inspect the governor next? My 91 Blazer also has the 700 R 4 and has an overdrive relay, but I can't find any reference to one on the Vette. Any ideas?
Old Dec 7, 2009 | 07:08 PM
rodj's Avatar
rodj
Screwed up
Old Dec 7, 2009 | 08:11 PM
larry00's Avatar
larry00
Sensors get gummed up with crap ! Had a 700 R 4 do the same thing in an IROC Z ! I was out of town so I put in a can of Seafoam Transmission conditioner which must have cleaned it up enough to drive a couple more years ! Tar that's the gummy stuff !
Old Dec 7, 2009 | 10:50 PM
rodj's Avatar
rodj
Screwed up again
Old Dec 8, 2009 | 01:23 AM
corvettedan22's Avatar
corvettedan22
good info. Hopefully mine keeps going strong !
Old Dec 8, 2009 | 07:06 AM
Pete K's Avatar
Pete K
Auto or stick?
Profile and opening post don't have this info.
Old Dec 8, 2009 | 08:04 AM
rodj's Avatar
rodj
Originally Posted by Pete K
Auto or stick?
Assumed ( never assume ) he was talking about a stick on account of the O/d relay reference.
Deleted
Old Dec 8, 2009 | 09:13 AM
Blackhole's Avatar
Blackhole
Sorry for the confusion, it is a auto TH700R4.
Old Dec 8, 2009 | 09:17 AM
Pete K's Avatar
Pete K
Since all other gears are normal, I would expect it to be a valve body or 4th servo apply problem.
Old Dec 8, 2009 | 01:14 PM
corvettedan22
Yeo, im out now also ! We all get confused I take it back !
Old Dec 9, 2009 | 12:57 PM
loaded vet's Avatar
loaded vet
Default Check OD switch
I don't know what year your vet is, however, ther is a switch on your brake pedle which signals the ECM when to engage and disengage the solenoid in the trans which locks it up. Some times this switch goes bad or loosens. I had this problem which turned out to be a loose switch at the brake pedle.
Hopefully this helps.
Gary
Old Dec 10, 2009 | 06:47 AM
rodj's Avatar
rodj
Originally Posted by loaded vet
ther is a switch on your brake pedle which signals the ECM when to engage and disengage the solenoid.
The ECM controls the lockup.
The brake switch is only there to break the circuit to the trans and disengage the lockup when you brake.
The OP's problem is no 4th gear ; not no lockup
To 85 lost overdrive
