z06 engine in a C4
Old Dec 12, 2009 | 08:27 PM
mike100's Avatar
mike100
I hope you are a fabrication guy and can do most of the work yourself...otherwise I hope you are rich. It would be more cost effective to stick with the standard smallblock as everything is externally dimensionally the same. the 450hp built small block is the same as the 240 hp stocker so you won't have to trash everything that bolts to it and start over with custom brackets.
