C-4 top differences
Old Dec 15, 2009 | 08:53 PM
jrd1990zr1's Avatar
jrd1990zr1
Default C-4 top differences
I understand 3 styles of top were used on a C-4 coupe; 84 to E86, L86 to 88 and 89 on.
Does anyone know what the differences are? Is it distance on front attachment or something more. Any one know a website that explains the differences?
Thanks,
Old Dec 15, 2009 | 08:56 PM
LT4 F45's Avatar
LT4 F45
distance between front attachment but i think 86L-88 and 89-up are interchangeable...
Old Dec 15, 2009 | 09:02 PM
Goldcylon's Avatar
Goldcylon
From Ecklers. Best quick visual of the difference in the mounts
Old Dec 15, 2009 | 09:04 PM
chuck13's Avatar
chuck13
yes,the front attachment is different,otherwise they
are all the same
Old Dec 15, 2009 | 09:06 PM
chuck13's Avatar
chuck13
dammit!i was lookin for that and could'nt find it!
Old Dec 15, 2009 | 09:07 PM
jrd1990zr1's Avatar
jrd1990zr1
Thanks GC and Chuck.
So the 2nd and 3rd design are interchangeable?
Thanks again, John
Old Dec 15, 2009 | 09:26 PM
RollaMo-LT4's Avatar
RollaMo-LT4
St. Jude 15 Year Donor
2021 C4 of the Year - Unmodified Finalist
St. Jude Donor '10 thru '25
Some very good reading here:
http://forums.corvetteforum.com/c4-t...-c4-roofs.html
Goldcylon's Avatar
Goldcylon
Thanks again, John
No the hardware is different as you can see the shape and the offset is slightly off. I am unaware if you can simply remove the hardware from one to the other although the panel itself is identical. I do know however that and 89 top will fit all MYs C4 from 89-96 and vice versa.
See the above post even better pics of those brackets so you can clearly see the differences. GC
Old Dec 15, 2009 | 10:58 PM
timbradley26's Avatar
timbradley26
thankyou for the link i have been trying to figure out how to adjust it now i now what to do . happy holidays
Old Dec 16, 2009 | 10:04 PM
Livin the Dream's Avatar
Livin the Dream
I also know that the 89 and up top will fit the 86l-88. You have to buy the front mounts for the car as well as a the trim piece. then you can swap the mounts to match the targa. There used to be a kit now you have to go to a vette recycler for these parts or fleabay
Old Jan 2, 2026 | 04:18 AM
Tof's Avatar
Tof
Hi !
If I understand correctly, for my 84-86E, if I want to put on a post-1989 t-top, I will have to:
- change the front mounting brackets above the windshield.
- modify the front upper windshield trim panel, that is to say, drill 2 new holes for the new spacing of the roof fixing screws, correct ?
But if I always own the original roof, can I just remove the mouting brackets that were on my old roof and install them on the new one ? If it’s possible ? I presume no... but i wonder
Thanks !
Old Jan 2, 2026 | 10:27 PM
typical boomer's Avatar
typical boomer
Another useful link.
https://mirrockcorvette.com/c4-parts-guide/targa-tops/
To C-4 top differences
