Paint code # for 85 runners, plenum & valve covers.
Old Mar 2, 2002 | 05:08 PM
djpearn's Avatar
djpearn
Default Paint code # for 85 runners, plenum & valve covers.
I have to paint these parts and I want them to look just like they came new from the factory. Has anyone done this job and what paint did you use, how well did it turn out, etc. I have never had much luck with spray painting things, does'nt seem to matter how I prep the surface, it will peel with in a year :mad. Because I really want this done right I had thought of taking them to a auto paint shop but I need to find the paint code # that was used. Thanks. :cheers:
[Modified by djpearn, 4:09 PM 3/2/2002]
Old Mar 2, 2002 | 09:41 PM
Bill Reid's Avatar
Bill Reid
Default Re: Paint code # for 85 runners, plenum & valve covers. (djpearn)
Runners and plenum, as far as I know, were bare aluminum from the factory. Not sure what EXACT color the valvecovers are suppoed to be but there are several silvers out there that will closely match. I had my plenum, runners, and valvecovers all powdercoated Class A Silver. To me the color is close enough...:)
Old Mar 3, 2002 | 11:38 PM
tzzzn2's Avatar
tzzzn2
Default Re: Paint code # for 85 runners, plenum & valve covers. (billreid1@***.net)
The spray paint that Mid-America sells for the valve covers is a perfect match. Bill
Old Mar 3, 2002 | 11:44 PM
scorp508's Avatar
scorp508
The plenum and runners are bare aluminum. The valve covers are a sort of blend between silver & magnesium color. Keep in mind the valve covers are in fact made out of magnesium, so be careful if you do any work to them. Mg burns BRIGHT! :D
Old Mar 4, 2002 | 10:15 AM
djpearn's Avatar
djpearn
Default Re: (scorp508)
Ok, just so I understand correctly, the runners and plenum were never painted or coated with "anything" from the factory, just bare aluminium, but the valve covers were painted/coated and thats why they turn a brownish colour after time or is it just a reaction/oxidization of the magnesium with the fumes and heat under the hood.
What I am trying to do is keep things in good original condition, but if I go painting things that never started out that way then I will probably end up with a big mess. My runners are both dented due to work by the PO :mad so I figured if I picked up a undamaged set I would just paint the whole lot.
Murphys Law has a special interest in ALL my projects :rolleyes:
[Modified by djpearn, 9:22 AM 3/4/2002]
Old Mar 4, 2002 | 10:22 AM
scorp508's Avatar
scorp508
The valve covers have a very strong and thick coating of primer on them, and a super thick coating of paint. The reason being that the castings are SO bad, GM dumped on extra paint to help fill in the casting marks. The brown you are seeing is indeed oxidation over time of the paint from the heat in the engine compartment. Also cleaning agents help brown them faster.
Old Mar 4, 2002 | 10:50 AM
Marcho Polo's Avatar
Marcho Polo
2023 C8 of the Year Winner - Unmodified
2020 Corvette of the Year Finalist (stock)
2019 C7 of Year Winner (stock)
Former Moderator
Cruise-In I-II-III Veteran
Default Re: (djpearn)
correct that the intake was bare aluminum from the factory....
I had mine all apart and wanted to paint the valve covers since they were the rusty color. I painted the whole intake with the valve cover paint that mid america sells and I think it looks great. see for yourself:
Before:
After:
This was done over Thanksgiving weekend and it still looks great. I drive the car everyday, rain or shine so it gets dirty under there. Washes right off and cleans up nice!
Old Mar 4, 2002 | 11:07 AM
dgoodhue's Avatar
dgoodhue
Default Re: Paint code # for 85 runners, plenum & valve covers. (tzzzn2)
Unless MAD has changed their paint formula, I don't think it matches perfectly. When I painted my stock one with the MAD paint it seemed to silver, I bought a brand new set of valve covers and the paint didn't match.
[Modified by dgoodhue, 10:10 AM 3/4/2002]
Old Mar 4, 2002 | 11:43 AM
Ron78Z&66Vette's Avatar
Ron78Z&66Vette
Bill...The powdercoating looks good. About how much did it run you?
Old Mar 4, 2002 | 01:30 PM
Joe C's Avatar
Joe C
the plenum and runners are bare aluminum. when i did a cosmetic restro on my engine compartment, i disassembled the runners/plenum from the intake, cleaned, degreased, (glass) bead blasted ,and coated with a (clear) chem-film solution (either 3M or DuPont - ???), and reassembled. the valve covers were repainted using mid america's valve cover spray. the chem film protects the bare aluminum from the elements. it soakes into the pores of the aluminum, and doesn't show any signs being coated. after five years, no signs of aluminum oxidation on the aluminum parts. i also did the smog pump, alternator, and mounting brackets.
Old Mar 4, 2002 | 07:57 PM
djpearn's Avatar
djpearn
A BIG THANKS for all the responses and pics. This makes the project much easier knowing the outcome wont be as crappy as I thought. All the cars look :cool:. Can't wait till mine looks that good. Now all I have to do is wait for better weather (and get a set of undamaged runners). :cheers: to all.
Old Mar 4, 2002 | 08:24 PM
Bill Reid's Avatar
Bill Reid
Default Re: Paint code # for 85 runners, plenum & valve covers. (Ron78Z&85Vette)
About $80 for the plenum, runners, and valve covers at Arizona Powedercoat in Phoenix. Although its not perfect, IMHO, it does fill in the casting imperfections a little better than paint.
Old Mar 4, 2002 | 09:53 PM
LWesthaver's Avatar
LWesthaver
Bill, your powdercoated plenum, runners and valve covers look real nice. As an aside, Have you ever tried using a standard household paintbrush soaked in car wash soap to clean your air intake boot? I find this works really well for getting the dust/dirt out of the pleats in the boot. I use a variety of different size paint brushes for cleaning all the odd shaped parts under the hood.
[Modified by LWesthaver, 8:55 PM 3/4/2002]
Old Mar 4, 2002 | 11:47 PM
snaketr's Avatar
snaketr
Default Re: Paint code # for 85 runners, plenum & valve covers. (LWesthaver)
Actually the valve covers were not painted, it was more along the lines of a plating process that was used on them. This is why the turn brown if the wrong cleaners were used on them. The plating reacts to degreaser etc and then turns to the rust color. The plating is very hard to get off, all who have tried blasting them no what I mean. You can use a cleaner like purple cleaner or simple green to clean the covers, then carefully dry them and paint them. You don't have to buy any special spray paints from MAD or anything, just get some cast aluminum paint. Make sure it is cast aluminum and not aluminum or else they will look like fake chrome. It is easy to do, just remember once you have painted them you will not be able to degrease, like with purple cleaner your engine. It will streak the covers. As far as the TPI unit itself, go to your local autoparts store and buy some aluminum wheel etching acid cleaner. This will make it look brand new, just make sure you wear gloves when you do this.
Old Mar 5, 2002 | 11:43 PM
djpearn's Avatar
djpearn
Default Re: Paint code # for 85 runners, plenum & valve covers. (snaketr)
More great info. :cheers:
To Paint code # for 85 runners, plenum & valve covers.
