Can someone please tell me how do you get to the battery to change it out.I see the post but darn this looks like a JOB!! Please Help!! Would like to drive today
From: Supreme Soviet Peace-Loving Pipple's Kollektive of Seattle Wa
Ditto! I've replaced 2 batteries and I've always had to wiggle them up and through the crossbrace opening leaving a lot of my skin with it. putting them in was easier as I had gravity's help. still, more skin. definitely gonna' try this procedure next time!
It should tell you in your owners manual. Though with regards to the above link. I don't see the point in loosening the lower side rocker panel, as I never had to do that.
Loosened the two bottom screws and took out the top screws on the side panel. Leaned the panel out and also took the two screws that hold the cruise unit and moved it out of the way. Loosened the screw holding the battery down, took off the terminals connections and the battery comes up and out on a angle. Under a hour to do when you add the beer breaks. Not very hard - though it depends on the duration of the beer breaks.
Much easier and quicker to just take the side panel completely off.
