Need help, will these fit!!
Old Jan 1, 2010 | 10:23 AM
therbst's Avatar
therbst
Default Need help, will these fit!!
I'm was hoping to purchase these from a forum member but I can't seem to find out if these will fit. I have a 1995 LT1 coupe with a stock motor. I was looking to dress up the engine bay and thought these would look great. Being new to the vette world, I'm not sure that these will:
Fit my stock LT1 motor
Is there enough clearance of the rockers
Are the holes in the top of the covers just breathers, or is one an oil fill
Is $50 a good price for these
Thanks for the help the link to the part is below.
http://forums.corvetteforum.com/c4-p...s-50-00-a.html
Old Jan 1, 2010 | 12:27 PM
NMsharkracer's Avatar
NMsharkracer
From: Formerly from the Great White North but now residing in the Desert Southwest NM (The Land of Dis-Enchantment?)
I don't think they will. primarily, aftermarket LT1 valve covers have to have a notch under the alternator bracket. The holes in those are for the PCV plumbing. They most likely would work on an L98. No oil fill so oil would have to added by pulling out a PCV grommet.
Old Jan 1, 2010 | 05:06 PM
RedVette84's Avatar
RedVette84
Might not be that great a price if you have to have any holes machined in. I was looking at some covers and they required machining for the extra hole that I needed.
Old Jan 1, 2010 | 08:23 PM
rodj's Avatar
rodj
Originally Posted by NMsharkracer
primarily, aftermarket LT1 valve covers have to have a notch under the alternator bracket. .
Only if they are taller than stock; the stock covers are not notched for Alt clearance
Old Jan 1, 2010 | 11:12 PM
therbst's Avatar
therbst
rodj- so if the covers that the forum member is selling are the same height or taller, then they should fit. I also realize that addding oil would be thru the breather port (no big deal). And because mine is in winter storage, I can't verify the notch, but your saying there are none. Well thanks for all your help and if anyone else has something to add I'll verify height and go from there. Thanks again
To Need help, will these fit!!
