TB bypass caps
Mar 4, 2002 | 11:30 AM
TB bypass caps
Those of you that have done the TB bypass ,what did you use to cap the fittings on the tb and where did you get them thanks Jim
Mar 4, 2002 | 11:38 AM
Re: TB bypass caps (Jim D)
I got some large vacuum caps from Pep Boys.
Mar 4, 2002 | 11:44 AM
Re: TB bypass caps (Ron78Z&85Vette)
I cut mine off. :eek: I just got large tube runners, and would need to alter the IAC housing anyway. My air pump is coming off as soon the weather warms up, and I'm polishing all the cast aluminum under the hood. Just figured it would look cleaner flush with the TB.
Mar 4, 2002 | 12:14 PM
From: Airport Cruise-in 1 Veteran Airport Cruise-in 2 Veteran
Cruise-In II Veteran
I bought the bypass hose connector, 2 clamps and TB caps all at the local auto parts store.
Mar 4, 2002 | 01:21 PM
Got some black rubber caps at a home store like Home Depot. Had to buy two different sizes as one tube was larger then the other.
Mar 4, 2002 | 08:56 PM
Re: TB bypass caps (Carroll B)
:yesnod: rubber caps from Auto-Zone
Mar 4, 2002 | 09:34 PM
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
Jim, when I do my 93 TB bypass, I'm going to use the hose from a 95, that way the "T" is eliminated altogether.
Re: TB bypass caps (Mr Mojo)
of course before I do that, I'm going to make sure that will work.
Mar 4, 2002 | 11:47 PM
Cruise-In V Veteran
Simple rubber cap from Napa!!!!
:cheers:
Mar 5, 2002 | 08:18 PM
Both at Pep Boys :yesnod: :seeya
Mar 5, 2002 | 10:12 PM
Hey, Mojo are you referring to the tee in the upper radiator hose?
I was looking at that but, it runs through the heater core don't it? :rolleyes:
Mar 6, 2002 | 12:16 AM
Re: TB bypass caps (CEEFOUR86)
Got mine at Advance Auto Parts. Cost me nothing, the guy gave them to me for free.:)
Mar 6, 2002 | 11:06 AM
Cruise-In I Veteran
On my '94 I got the 95/96 hose, thus eliminating the "T". Also, got two generic caps ... got the whole thing from local NAPA. Can't remember price but it seems the whole thing was around $10.00. Very easy mod. Just remember to drain a little coolant off to avoid spillage.
