COLD Whine
Start up has a 'loud' whine from under the hood. As the car warms up, approx. 5 minutes, it quiets down.
Last night I observed the digital battery voltage readout: Cold start 15.1
A few minutes later 14.9; after 20 minutes of driving 14.7; and when I got hope 40 minutes later 14.3,
Does this sound normal? Could the whine be an alternator ready to go out?
In normal weather there isn't the whine, but the air pump IS fairly loud.
Thoughts & direction most appreciated...
See what happens when you start the car and start turning on some power users like rear window heater, if it stays in the +14 volt range, there is nothing wrong.
If you turn off the engine (after 10-15 minute drive), read it again.
It will most likely be around 12.5 volt, wich is OK.
If it´s under 12 volt, you might be in the market for a new battery.
My air pump is also loud, it´s their way of letting know they are there too.
I think they feel lonely sitting all the way up there...
Any thoughts? Any way to stop the noise?
Get your self a multimeter and test the battery terminals with engine off, then with engine on. Avg. of 12.9~13 is okay with engine off, 13.6~14+ with engine on. Of course YMMV, but you get the drift.As for the alternator, see below. On that note, the air pump is such a waste of space. Anyway, for a dump fix
you can try squirting some WD40 in it through the holes and see what happens. Other than that, you can either spring for a new old stock airpump (I'd say don't), get a junk yard part, or do what I did... get the air pump eliminator kit.
If it's indeed the alternator, you can either live with it until it dies or take it off and find a local alternator rebuild guy and let him repack the bearings (or fix whatever's worn out) Other than that, no way to quiet it, it's not like there's places to squirt grease. My advice if you guys ever get new/rebuilt alternators get it here:http://www.alternatorparts.com./CS-1...cial_offer.htm
I tossed my crappy CS130 with a robust CS144 and never looked back. Lasted me a good 5+ years until I had it rebuilt by a local guy. No doubt it'll be good enough for another few.
Best simple response! Guys, try look/hear for where the problem is first. Then come back and report.
All good areas to check. However to the OP, my bet's on the alternator or the air pump... you can only tell by putting your ear close to each one and find out. Be careful though!
Good luck.
Been experiencing rough cold starts past week. it was 17 this morning. had trouble turning over.
Heading out to pull it off now.
