Going to try powdercoating.
I just bought the harbour freight kit and red powder coat a couple of days ago, today went and picked up a large oven with two seperate oven compartments.
Tomorrow I'm going to wire the Oven in and the next couple of days going to try my hand at it. It should be fun and I'm sure I'll powdercoat everything I can pickup and stuff in the oven.
I've already made sure to use my carport for the experiment so it wouldn't stink up the house or my shop. Later I may add another addition to my bike/vette shop for this hobby.
cool, I almost bought one from them about 10 years ago, and decided, I would quickly run out of things to coat.
I think it will be fine, it is a little different than painting with liquid.
Ya know, I tend to go overboard too....I can see myself running out of things to coat but still wanting to do it. Next thing I would be powdercoating the dishwasher, the iron, the neighbors mailbox, the vacuum cleaner....and dismantling each so it would fit in the oven. Then I would get a $600 electric bill for running the oven 24/7. Could get ugly in a hurry.
Sounds cool.
Do you have a sandblaster to prep the stuff you want to paint, or doing it mostly by hand?
[IMG][/IMG]
Midnight85 just finished a major engine rebuild for me and did some GREAT powder coat on mine.
Here is the valve covers out of the oven
Here is the finished job with plenum powdered also
common errors;
1) poor grounding...if your pant legs 'cling' to your leg when you trigger the gun, look for grounding prob (wall outlets often are not good grnd)
2) dirty parts...unlike wet paints, powder has '0' solvent in it and will not 'dig its own fox', even fingerprints may cause lack of adhesion
3) 'Faraday cage'...tight inside corners may exclude powder due to this magnetic phenomenon
4) bake time/temp must follow powder mfr's recommend
5) keep your powder dry.
Hi I have a Harbor Freight powder coating gun. I found it really makes a mess outside in driveway and wind is a problem. I didn't want to do it inside but I'm making a simple box w/filter and fan to control this a little better. I second the advice on preheating parts, It looks look much better doing it also! I wouldn't buy your powder from HF you can buy used powder from places that have big runs of parts and have left over powder. Most times you can buy it for less than a dollar pound. search the web there are sites that tell you how to build your own powdercoat oven. I want one big enough to do quad frames, They charge big money to do these I think you could make good money doing it at home. So far I do mostly small parts that I blast myself or sometimes I use a vibratory polisher filled with different media.Sometimes that's much easier,you just throw parts in and let it run for a few hours.The best powder is the fake chrome, some of these need to be clear coated after though. also check out the translucent powders they are 3 stage process but look like candy automotive paints. One thing I did was contact various powder coat companies for samples not telling them I only did it at home, they will send you 3 to 5 lbs free to try their powder. as it takes that much to try it in a big machine but that goes a long way at home. Good Luck Tim
