Missing wheel lock key.
Old Jan 8, 2010 | 10:50 AM
70blueshark's Avatar
70blueshark
Default Missing wheel lock key.
A buddy of mine just bought a 1989 Corvette, but the previous owner lost the wheel lock key. He said he didn't see one in the Mid America or Corvette Central catalogs. As a C-3 guy I don't have much info on C-4s. Can any of you guys tell me where I should have him look? Thanks.
Old Jan 8, 2010 | 11:04 AM
Goldcylon's Avatar
Goldcylon
Unless you have the key number you wont be able to order a replacement key. Your best option is to remove the old locking lugs and start over.
Go to sears and get an easyout socket. You tap the socket on top of the locking lug nut and it cuts a reverse groove into the lug which will allow you to loosen the wheel.
Another option is to weld a regular nut untop of the old locking nut and turn it off that way as well. Just wrap the area with a moist towel first then weld away
Good luck GC
Old Jan 8, 2010 | 12:40 PM
70blueshark
Thanks. I'll pass along the info.
Old Jan 8, 2010 | 01:26 PM
pologreen1's Avatar
pologreen1
Good luck GC
Also I have been thru this, you can call shops some will take the lug off for you. (tire shop)
Old Jan 8, 2010 | 01:56 PM
Frizlefrak's Avatar
Frizlefrak
Good luck GC
I think ALL of us have been through this before. I did the welding trick...just used a welding blanket draped and taped to protect everything, put a nut over the lug nut, and laid down a bead on it. Let it cool, put a standard socket over it, and off it came.
JMHO but I'm not a big fan of locking lugs. It seems they give car owners more trouble than they give thieves. That's what insurance is for.
Good luck.
Old Jan 8, 2010 | 06:23 PM
RedVette84's Avatar
RedVette84
If it's stock lock would a dealer possibly have a master key?
Old Jan 8, 2010 | 07:31 PM
c4cruiser's Avatar
c4cruiser
Hard to say if dealers have "master keys". There are assorted patterns to the ribs on the lugnut and key that there could be a dozen possibilities.
A tire shop will be able to remove the factory lock. If your buddy wants to retain a wheel lock, there are ones available that will work but he should consider ordering a spare key. I have done that in the past. One key stays in the car, the other is in the garage.
Also, the C4 and C5 lug nuts are the same so if a dealer says they can't get a C4 locking lugnut, get a C5 version.....
Old Jan 8, 2010 | 08:01 PM
Camaro350z28's Avatar
Camaro350z28
I just had Americas tire company remove them. $5 apiece so it wasnt even a big deal
Old Jan 10, 2010 | 01:15 PM
partner22's Avatar
partner22
Default wheel wrench
I found one on e-bay. I then went to the Chevy dealer and they ordered one. Only $15.00. If it is the one that I am thinking. It is a nut hole on the center cap CORRECT.
If you cannot get one like I said I have two I will sell you one.
Bob
Old Jan 10, 2010 | 03:07 PM
1984 porn-mobile's Avatar
1984 porn-mobile
Its probaly a Mcgaurd set........ I contacted them and they sent me a new one after I sent them a pic of my lugs..... Does it look like a star with rounded corners? If so most likely its a Mcgaurd.......
Old Jan 12, 2010 | 11:23 AM
Bobs 1989 C4's Avatar
Bobs 1989 C4
1st Gear
Default Found the wheel cover locks for my 1989 Corvette
Thank You for the advice. It was a Mcgaurd Key. I call the company after looking on their
website. Told me to email three photos of the lock. They call me back with a match and the key is on the way to me. $17.00 each or two for $26.00. Also they had the matching locks, they were $10.00 each. After looking on the web for hours this is a great deal and THANK YOU for your help.
Old Jan 12, 2010 | 03:31 PM
eagleye's Avatar
eagleye
I stripped one of the bolts and then the wrench and I wasn't going to pay a bunch of money for new ones or even used on Ebay. Here is what I did.
I bought 4 stainless cap screws and drilled a hole in the middle to insert a pin. I had to turn the diameter of the head down a bit so it would fit in the cap. Went to Advance Auto and bought a small ratchet wrench and the security wrench. It's not the original but they look nice and the work.
To Missing wheel lock key.
