View Poll Results: Hoosier 275 40 R/17 drag radials
Pretzle a half shaft
50.00%
Grenade the D44
7.89%
NADA.....everything will be OK
31.58%
what this isn't a zaino thread????????
10.53%
Voters: 38. You may not vote on this poll
What will happen first.
Old Jan 12, 2010 | 07:45 PM
aboatguy's Avatar
aboatguy
Default What will happen first.
The vert has been running ok pulls to 7K in D(3rd)...vibrations are GONE..
However, it won't hook....
so I have some Hoosiers on the way....with 17" OEM Z06 rims
one of my C4 buddies asked me what I thought was going to happen first:
pretzle a halfshaft or break the snout off of my D44.
I believe everything will be ok, but heres the poll.
Pretzle a halfshaft
break the D44
NADA damn thing
Old Jan 12, 2010 | 07:54 PM
aboatguy's Avatar
aboatguy
Only one wheel arrived so far.....
UPS
Wheel one 275 40 R17 Hoosier drag radial with the nubs still on it and a OEM ZO6 wheel! (when other wheel shows up I'll run them into work and throw them on the hunter IOT balance them.
Old Jan 12, 2010 | 08:54 PM
Razor89's Avatar
Razor89
My stock 1/2 shaft went first and then the next time the Ujoint snapped off. That was with Nitto DRs 17x11 315
Old Jan 12, 2010 | 09:08 PM
Frizlefrak's Avatar
Frizlefrak
I say the half shaft is the weak(est) link. Only one way to find out.....
Old Jan 12, 2010 | 10:07 PM
kangi's Avatar
kangi
I'm an optimist, you'll be fine...don't quote me on that
Old Jan 13, 2010 | 06:42 PM
aboatguy's Avatar
aboatguy
The other drag radial came in....
Old Jan 13, 2010 | 06:55 PM
pologreen1's Avatar
pologreen1
how much power are you putting down?
If you have less than 500 hp I think you are safe on a d55 for a while at least.
Old Jan 13, 2010 | 07:20 PM
96z51's Avatar
96z51
i think you will be fine as long as far as not throwing parts out from under the car.
Old Jan 13, 2010 | 07:32 PM
aboatguy's Avatar
aboatguy
Considerably less than 500 horsepower at the tires..
Old Jan 13, 2010 | 09:03 PM
kimmer's Avatar
kimmer
C4 of the Year Finalist
Old Jan 13, 2010 | 09:11 PM
JackDidley's Avatar
JackDidley
Go ahead and get some halfshafts in stock. And a bearing assembly. You will need both for the passenger side.
Old Jan 13, 2010 | 10:22 PM
pologreen1's Avatar
pologreen1
OK now I voted
Old Jan 14, 2010 | 12:43 AM
mazdaverx7's Avatar
mazdaverx7
the dana 44 is pretty strong..you'll likely chip up the ring and pinion with over 500hp but the driveshafts to the rear wheels will be weakest at teh u-joints.
Old Jan 14, 2010 | 11:02 AM
ZumZum's Avatar
ZumZum
I vote for destroying the tranny.
Old Jan 14, 2010 | 04:54 PM
nutz4c4's Avatar
nutz4c4
Half Shaft...
Old Jan 14, 2010 | 06:51 PM
aboatguy's Avatar
aboatguy
Thanks!!!just had this one redone when I jacked up my 2800 stall torque converter....so I had the tranny redone and bought a 3500 Vig.
To What will happen first.
