89 brake problem
Old Jan 12, 2010 | 08:26 PM
arborist's Avatar
arborist
2nd Gear
Default 89 brake problem
before doing a brake job I wanted to flush all old fluid with vac pump all bleeders except right front will flow fluid fine right front will only give a very small amount of fluid at bleeder so i unhooked rubber line from metal line same result there.I went under car undid coupling at drivers side same result with vac pump hooked up there at 25psi fluid drips out 1 drop at a time that is the line that goes to the abs unit in the rear Can any one offer any possible solutions
Old Jan 12, 2010 | 08:31 PM
RicK T's Avatar
RicK T
Hey, welcome to the Forum!!!!!!!
Just FYI, this "Help" Forum is for getting help with the operation of the Forum itself.
For questions about your C4 Corvette, go into the C4 General Forum and ask there. The members will help you out. Good luck.
http://forums.corvetteforum.com/c4-g...discussion-34/
