1995 corvette spark plugs
Old Jan 21, 2010 | 03:03 PM
grzsport's Avatar
grzsport
Cruising
Default 1995 corvette spark plugs
I am going to change the spark plugs on the 95 vette. I was going to go with factory ac delco, except the dealer is out and it will be a couple of days or longer. I have heard about people running NGK plugs, (thought those were for imports) any suggestions on spark plugs would like to have them done by this weekend.
Old Jan 21, 2010 | 03:35 PM
aminnich's Avatar
aminnich
A lot of people use and recommmend the NGK. I think I remember TR55 as the exact model.
Old Jan 21, 2010 | 04:01 PM
Nowhere Man's Avatar
Nowhere Man
2015 C2 of Year Finalist
you shouldn't have to go to the dealer for spark plugs. I bought mine from Advance Auto parts. but all the major parts places should be able to get them
Old Jan 21, 2010 | 04:07 PM
1slov6's Avatar
1slov6
Old Jan 21, 2010 | 04:14 PM
H P Bushrod's Avatar
H P Bushrod
Moderator Emeritus
St. Jude 15 Year Donor
CI 5 thru 12 Veteran
St. Jude Donor '09 thru '23
NGK TR55's have been in my '93 LT1 for 3 years. No problems at all.
Old Jan 21, 2010 | 04:15 PM
TWISTERUP's Avatar
TWISTERUP
the TR55 is a 30K mile plug ,but I've been pleased w/them.
JMO- I don't believe AC plugs are as good as they were years ago.
Old Jan 21, 2010 | 04:24 PM
Nowhere Man
they work fine for my daily driver
Old Jan 21, 2010 | 06:41 PM
RichS's Avatar
RichS
Every 95-96 I've pulled the "factory" plugs out were always missing at least 50% of their platinum pucks. ( made the gap around .070) Didn't matter if it had 12,000 or 50,000 miles. I would not use them ever. I put NGK in everything and have no problems with them.
Old Jan 22, 2010 | 09:40 AM
onedef92's Avatar
onedef92
Cruise-In IV Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VIII Veteran
Stock or lightly modded LT1 in the O.E.M. heat range? NGK TR-55 Double Platinum. You won't be dissapointed.
I also had good experience with Autolite Platinum.
Old Jan 23, 2010 | 05:49 AM
mazdaverx7's Avatar
mazdaverx7
i've been using NGK UR4's in my 84 with outstanding results.
Old Jan 23, 2010 | 08:37 AM
Freedom95's Avatar
Freedom95
Default 95 Spark Plugs
I've got a 95 convertible with 108,000 miles and just replaced the sparkplugs. I had put in the oem AC Delco plugs 50,000 miles ago and just replaced them with the same. No pucks were missing after that amount of miles and I'm happy with these plugs. The gap had increased some from the 0.50" gap as is normal after plugs have been in for awhile. I'd recommend changing these plugs at shorter intervals than the 100,000 miles that's recommended by Chevy so the gap doesn't get too big.
Rember to apply some anti-sieze material to the plugs and the proper lube to the inside of the sparkplug boots. Both will make it much easier to change the plugs next time.
Old Jan 23, 2010 | 11:01 AM
BackInBlack96's Avatar
BackInBlack96
Stupid question time: what is the gap supposed to be? 0.030" ?
Old Jan 23, 2010 | 11:16 AM
STL94LT1's Avatar
STL94LT1
.050
Another vote for the NGK TR55's. The last set I bought cost ~$15.
To 1995 corvette spark plugs
