Temp Gauge Sensor
Old Jan 21, 2010 | 05:06 PM
jmcquade's Avatar
jmcquade
Default Temp Gauge Sensor
I reacently bought an 87 Vette but notice the temp sensor coming out of the head behind the oil stick seems to have a wire with a little connector on the end but not connected to anything. Does anyone know where this should connect to?
Old Jan 21, 2010 | 06:10 PM
Millah's Avatar
Millah
On my 89 the temp sensor is on the front of the motor above the waterpump. You may be looking at the knock sensor?
Old Jan 21, 2010 | 06:13 PM
rodj's Avatar
rodj
Is temp gauge sensor
You are looking for the green wire that comes up from below out of the harness that runs to the knock sensor and starter.
Sensor at front is coolant temp sensor ( CTS ) for temp input to computer ; not sender for temp gauge
Old Jan 21, 2010 | 09:25 PM
jmcquade's Avatar
jmcquade
Thanks!!!! The Haynes Book does not tell you anything. Thanks!!!!
Old Jan 22, 2010 | 08:41 PM
vetteoz's Avatar
vetteoz
That is why most use it in the toilet and not for reading
Old Jan 26, 2010 | 01:13 PM
jmcquade's Avatar
jmcquade
Does it come out below the motor? I can not seem to see where the wire disconnected from.
Old Jan 26, 2010 | 05:59 PM
rodj's Avatar
rodj
There is a small harness that runs down to the starter motor.
Contains the starter solenoid wire (heavy purple? ) the knock sensor wire and the temp gauge wire
Old Jan 28, 2010 | 12:26 PM
jmcquade's Avatar
jmcquade
OK The wire Run up from below the motor and the just above the exhaust manifold and stops. Where does the other end go? This thing is driving me nuts!!!
To Temp Gauge Sensor
