dent?
Old Jan 25, 2010 | 07:09 PM
1stL98's Avatar
1stL98
Default dent?
i was changing the oil on my 85 coupe and noticed a "dent"on the pass side floor pan.its not cracked or broken.what do i do to pop it back.
Old Jan 25, 2010 | 07:13 PM
kimmer's Avatar
kimmer
C4 of the Year Finalist
If its glass , nothing, its not unusual to have a few scrapes and minor dents in the metal on the undercarriage
Old Jan 26, 2010 | 02:44 AM
SQUIRMIN VERMIN 84's Avatar
SQUIRMIN VERMIN 84
From: Supreme Soviet Peace-Loving Pipple's Kollektive of Seattle Wa
wait untill you doge a few boards and other road debris....makes a horrible noise when you're sitting so low!
Old Jan 26, 2010 | 08:22 AM
Tommy T-Bone's Avatar
Tommy T-Bone
St. Jude Donor '06-'07-'10-'11-'12-'13-'14
If it's not leaking or causing a problem, I'd leave it alone. Have you ever broken something while trying to fix it?
Old Jan 26, 2010 | 01:53 PM
Randy T's Avatar
Randy T
How big is the dent? Does it looks like it was caused by something on the road in the past? Or by improper jacking, which is very common? Does it cause one of the seats to sit awkwardly? The floorpan itself is steel. You can take out the seat and use a mallet to beat it back down if it's not severe - which, as you briefly described it, doesn't sound like it is.
Old Jan 26, 2010 | 03:08 PM
1stL98's Avatar
1stL98
yes the seat on the pass side does sit high on the drive shaft side.i was thinking about the rubber mallet,but someone said the floor is fiberglass.it looks like steel.my guess is a land on something dent awile back.
Old Jan 26, 2010 | 05:25 PM
bdw18_123's Avatar
bdw18_123
From: Prather, California -1990 ZR-1 White/Flame Red- -SOLD!!-
My '90 ZR-1 had the same issue on the driver's side seat, left-hand rear seat bolt stud area. Was dented from the bottom from scraping over something or improper jacking. Yes, the floorpan that the seats are bolted to is steel.
After removing the seat, I pounded the dent back out with a 2x4 piece of wood and a hammer.
Old Jan 26, 2010 | 06:09 PM
ks5shooter's Avatar
ks5shooter
St. Jude Donor '10-'11-'12-'13
waaaaaaaaaaaaaaaaaay true!!!!!
Old Jan 26, 2010 | 06:35 PM
FOURSPEEDVETTE's Avatar
FOURSPEEDVETTE
Now you know, when you have to lift the car be sure the pads from the lift are positioned on the spots marked with arrows under the rocker panels. Someone must have put a jack under the floor pan in the past. I had a 1966 Mustang fastback a few years ago. I brought it to get new tires a local tire shop. The dumazz put two floorjacks under the rear floor and started lifting, and lifting, and, well you can guess what happened. I had a (word) with him to show my disapproval. The floor looked like garbage underneath after they beat the h-ll out of with a rubber mallet. Be careful how you repair it.
Old Jan 26, 2010 | 11:12 PM
RedVette84's Avatar
RedVette84
You can always tell when someone jacked it up and didn't know what he was doing. I had a kid a few years back that tried to jack up my Mercury - it went up five different ways. Dented the floorboard and almost dropped it off the lift.
Old Jan 27, 2010 | 12:36 AM
pologreen1's Avatar
pologreen1
Old Jan 27, 2010 | 01:41 PM
1stL98's Avatar
1stL98
uughh the prices we pay for uneducated bufoonery
To dent?
