Battery Drain
Old Jan 27, 2010 | 09:16 PM
liebo's Avatar
liebo
Default Battery Drain
My brand new battery in my 86 vert with 20,000 miles drains in less than 3 days. I put a meter on it and it draws 2 amps every 8 seconds. I've read some of the other discussions, but this seems to be a larger draw. What should I be looking for? Is there a better way than pulling fuses?
Old Jan 27, 2010 | 09:57 PM
Frizlefrak's Avatar
Frizlefrak
No, not really. You're going to have to isolate what circuit is shorted or has a draw, and correct the problem. But with that large of a draw, I would start looking at things like the power seat rack, headlight motor, alternator, stereo equipment, amps etc.
When I had this happen it turned out to be a power supply in the digital cluster. I don't recall the specific amount of draw, but it wasn't as high as yours. It was draining the battery in about 3 days.
Sooooo...start pulling fuses until the draw disappears. Then narrow it down from there. Not fun, I know.
Old Jan 27, 2010 | 10:01 PM
liebo's Avatar
liebo
Thanks, that is what I will have to do.
Old Jan 28, 2010 | 06:36 PM
RedVette84's Avatar
RedVette84
If the light is on in the console it will drain it that fast. If I have too much stuff in the console it doesn't close right and the light will be on. I didn't see it until it was dark and then I had to look close.
Old Jan 29, 2010 | 09:09 PM
liebo's Avatar
liebo
I pulled the fuses one at a time while the meter was online. I found that the fuse that is for the seats and the power door locks was the problem one. Thanks for your help.
Old Jan 30, 2010 | 01:53 AM
Frizlefrak's Avatar
Frizlefrak
Sounds good. Check the motors on the power seat track and see if one of them is warm. Not uncommon. You can also unplug the track and test for current drain there. If the seat track is the problem, see if the issue is in the switches or the track itself.
Old Jan 31, 2010 | 12:34 AM
jfb's Avatar
jfb
It is moderately common for the seat adjust switches to stick on and the seat motor goes to the end of its travel and stalls, this draws high current and the seat motor circuit uses circuit breakers that reset themselves. What you are seeing is a stalled seat motor and a circuit breaker doing its job.
Old Jan 31, 2010 | 05:53 AM
olcrusty's Avatar
olcrusty
This is a old trick we used to use in finding a suspect circuit that is draining the battery. Make sure everything is off and the battery has a good charge or at least a battery charger is connected. If you pull one fuse at a time and then while re-inserting that one fuse you see any kind of spark that is the circuit that is suspect. There should be no spark when you re-insert the fuse because there should be no draw on that circuit. Try it, it works.
Olcrusty said that
Old Jan 31, 2010 | 02:28 PM
jfb's Avatar
jfb
olcrusty couldn't afford a VOM test meter.
Old Jan 31, 2010 | 02:41 PM
Frizlefrak's Avatar
Frizlefrak
Ahhh....the "fire up ol' sparky" method of troubleshooting.
Old Jan 31, 2010 | 03:12 PM
olcrusty's Avatar
olcrusty
VOM meter! We don need no stinking VOM meter!
Olcrusty said that
Old Jan 31, 2010 | 04:09 PM
mrmtrtrnd's Avatar
mrmtrtrnd
olcrusty could teach those young whipper snappers a thing or two.
To Battery Drain
