'91 with 156k
Old Feb 1, 2010 | 03:39 PM
vetteson91's Avatar
vetteson91
Default '91 with 156k
Hi everyone, I'm new to the forums with a question.
About to receive 1991 Corvette, and it has 156k miles on it.
What's it going to do to the performance and what kind of problems can I expect?
Thanks, I hope not too much
Old Feb 1, 2010 | 04:50 PM
kimmer's Avatar
kimmer
C4 of the Year Finalist
can you be a little more specific?
Old Feb 1, 2010 | 05:06 PM
mazdaverx7's Avatar
mazdaverx7
a lot depends on how teh car was maintained and what parts are new. also a list of issues with the car would help us help you.
Old Feb 1, 2010 | 05:14 PM
tblt44's Avatar
tblt44
Are yuo buying it or is it free.
You will have to do some work,I hope you can do it yourself or your pocketbook will get much lighter
Old Feb 1, 2010 | 05:32 PM
vetteson91's Avatar
vetteson91
Well, i got to drive it for a day, and there's not many problems.
It has HID lights, but for some reason there is no highbeams/foglights.
Whenever you floor it and let go right after it switches gears (its an automatic transmission btw), it makes a small screeching noise.
I also hear it squeak when you turn the wheel if you're outside.
Other than that nothing much. The brake is not as strong as I thought it would be though, if thats anything else.
Its going to be taken to a mechanic to change the set of brakes, change the oil and inspected I suppose, but I'm wondering what effect the age and mileage will have on say, 0-60 and quartermile times. Should be somewhere around 5 seconds I think, but I haven't gotten the chance to time it.
Old Feb 1, 2010 | 09:51 PM
RedVette84's Avatar
RedVette84
First thing I would do is change ALL the fluids.
Old Feb 1, 2010 | 10:00 PM
vetteson91's Avatar
vetteson91
Any common problems with this generation that aren't too obvious to notice?
Old Feb 2, 2010 | 10:44 PM
GKK's Avatar
GKK
Rear Intake Manifold usually leaks in the rear and a little coolant seepage could be seen towards the top front near the thermostat housing.
Stock Multec fuel injectors will eventually fail, replace with Bosch III injectors from www.fuelinjectorconnection.com $169 when the intake manifold is off. Also, change the EGR valve.
The water pump should also, be changed if it hasn't already.
To '91 with 156k
