'94 stereo removal?
Old Feb 6, 2010 | 12:39 PM
Tigerhawk's Avatar
Tigerhawk
Default '94 stereo removal?
I'm looking for a thread with instructions and pictures for stereo removal for a '94. I looked in the audio section, and the thread there is disabled. Anybody have any tips? Thanks.
Old Feb 6, 2010 | 01:37 PM
Goldcylon's Avatar
Goldcylon
Lift console door. Two bolts are located in the front postion of the console. They are under the carpet tabs. Next remove the bolt from the cup holder area. Now silde the console shift plate backards. If you have an auto be careful of the shift lens indicator it just fits on a little tab. If manual simply pull the shift plate backwards no shift indicator tab to worry about.
Two bolts are now exposed on the bottom of the radio surround bezel remove those but have a magnet on hand to capture those little buggers. Remove the A/C vent at the top of the radio surround bezel its held in with phillip screws, grab and pull it out. Now behind where the AC vent is is the last bolt for the radio surround remove it. Grab the radio surround bezel in the middle of the bezel. Two spring clips are whats holding it into place.
Pull it out of the way and the radio removal is obvious from this point forward. GC
Old Feb 6, 2010 | 03:44 PM
StealthLT4's Avatar
StealthLT4
Might be some helpful info in here:
Part I: http://forums.corvetteforum.com/c4-g...-i-no-56k.html
Part II: http://forums.corvetteforum.com/c4-g...ii-no-56k.html
Old Feb 6, 2010 | 05:02 PM
Tigerhawk's Avatar
Tigerhawk
Thanks guys The magnet tip came a little too late.
Old Feb 7, 2010 | 09:40 AM
jjamis's Avatar
jjamis
The bottom tabs on the dash bezel are brittle and fragile; be gentle with these tabs. If a tab breaks, use a washer to fasten the broken tab.
If you are putting in an aftermarket radio you will probably have to "clearance" the rear support for the new radio.
To '94 stereo removal?
