Check Engine Light?
Old Feb 10, 2010 | 03:31 PM
HONDOBUCK's Avatar
HONDOBUCK
Default Check Engine Light?
I have an 86 vette and anytime i cruise on the freeway with cruise control on for a while the check engine light comes on. When I turn the car off and start it again it goes off??? What is wrong?
Old Feb 10, 2010 | 03:42 PM
j-vette's Avatar
j-vette
St. Jude Donor '10
I think cruise works by vacuum so maybe bad line? what happens on the freeway without cruise engaged?
Old Feb 10, 2010 | 04:55 PM
HONDOBUCK's Avatar
HONDOBUCK
Umm its hard to say I havent driven it in a while because its winter But if I remember right I think it still comes on if I hold the pedal at the same place over a longer period of time. It doesn't come on when I am on and off the gas alot though Thanks for the help!
Old Feb 10, 2010 | 06:51 PM
azrocketman's Avatar
azrocketman
You need to read the OBD codes. You can do it with a paperclip. Do a search of the forum or look online because the "how to" is easily available. I'll place my wager right now on code 24 (vehicle speed sensor) or code 34 (mass air flow sensor).
Steve
Old Feb 10, 2010 | 09:41 PM
GIMMESOME's Avatar
GIMMESOME
You do need to pull the codes. My guess on an 86 will be a code 32 EGR failure. The CEL will come on, and then go off when you restart, but the code will be stored. The diagnostics on a code 32 are quite extensive.While I'm not an advocate of throwing parts at the problem, I would first try an EGR switch.That was the cause with my 86. It's cheap and not that hard to replace. Pull the codes and let us know.
To Check Engine Light?
