Leakin' Intake Manifold
Old Mar 7, 2002 | 05:53 PM
vetteman42's Avatar
vetteman42
Active Streak: 90 Days
Default Leakin' Intake Manifold
My '91 is leakin' again after having it replaced about 5 years ago. What is the best gasket to go with and are there any additional procedures/sealents that are recommended. I know this is a common issue with L-98s but, I would like to make sure the job is done with the right materials,etc.
Thanks and Save the Wave!
Old Mar 7, 2002 | 06:11 PM
Bluevette85's Avatar
Bluevette85
Default Re: Leakin' Intake Manifold (vetteman42)
How is it leaking? Air, oil, coolant? If it is the infamous rear oil leak, you'll have to remove everything. Try re-torqueing the bolts first. I use Felpro gaskets.
Old Mar 7, 2002 | 06:26 PM
vetteman42's Avatar
vetteman42
Default Re: Leakin' Intake Manifold (Bluevette85)
Thanks for your reply and question. It's coolant on the edge of the intake on the driver's side.
Many thanks....
Old Mar 7, 2002 | 07:43 PM
Bluevette85
If tightening doesn't help and you replace the gasket, put Permatex on the bolts. This will hold them in place and prevent coolant from leaking thru the mounting holes.
Old Mar 7, 2002 | 09:50 PM
J Z06's Avatar
J Z06
You mean a little like this?
I am going through the same thing. LPE built the motor in 1997. Not too bad, it just started piddling recently. It is coming apart soon.
Old Mar 8, 2002 | 02:32 AM
Vic'89's Avatar
Vic'89
I fixed the intake manifold gaskets 2 years ago.
This was the 2nd time they were done on my car.
The original owner had them done at 15K miles and I did them at 66K miles.
Vic
Old Mar 8, 2002 | 03:31 AM
RichAshley-Black99's Avatar
RichAshley-Black99
I have the same problem with mine i need to do it when i get back to the states, will it work if I just tork it down? My luck ill have to pull the whole thing off. :cheers:
Old Mar 8, 2002 | 10:08 AM
cajun86's Avatar
cajun86
OK here's what i did the mating surface on the neckis warped. I pulled it off and took a block of wood ( 2x4) and wrapped sandpaper around it and sanded the mating surface untill it was totally flat. Have not had it leak since .... :flag
Old Mar 8, 2002 | 11:21 AM
VetteBabe1's Avatar
VetteBabe1
Default Re: Leakin' Intake Manifold (cajun86)
Replaced mine twice in 5 years and 110k miles (74,600 to 186,000) on my old 87, used stock gaskets, no problems.
Old Mar 8, 2002 | 11:48 AM
LeadFoot's Avatar
LeadFoot
Fel-pro gasket, permatex "great stuff" rtv, dimple the front and rear mating surfaces. No leaks in 60k miles
To Leakin' Intake Manifold
