Need help ID brackets
Old Feb 12, 2010 | 05:17 PM
BogusSVO's Avatar
BogusSVO
Default Need help ID brackets
I have a box of NOS brackets, and when I googled it It lead me to your fourms.
the first one I have is 10105236, it should be an AC bracket.. acording to what I read in here..
http://forums.corvetteforum.com/c4-p...c-bracket.html
now the rest of the numbers I would assume would be for the same engine
14055113 the number is not on the bracket , but wire tied to it...
I will assume this is an PS bracket too
14087559 looks to be the same bracket, but with a few more strenth ribs to it
**** PS bracket
14063758 just on the sticker on it... looks factory..
an alt bracket??
14087520
A.I.R. pump bracket
14087519
another alt. bracket
all the above brackets/numbers are made of alum....
10105222 its a small steel bar, slot in one end and a nut on the other about 6" long... alt support ???
this is the last one not ID.. but I would bet it is a A.I.R. pump support bracket
14092391 steel, black, about 6" long slotted holes on both ends 90* twist
alt support bracket
Ill say thanks for any help!
I just like to find out what they fit.... and if I should keep them or not
Old Feb 12, 2010 | 07:09 PM
rodj's Avatar
rodj
Very few would know those # unless they had a parts book.If you were to put some pics up people could tell you straight away what they are for
Old Feb 13, 2010 | 10:41 AM
BogusSVO's Avatar
BogusSVO
I will work on getting some pics up... I knew it would be a long shot with out pics... Thanks again!!
Old Mar 9, 2010 | 02:43 PM
BogusSVO's Avatar
BogusSVO
Id like to thank Itshakes for all his help!!
To Need help ID brackets
