10-4 on giving the airbag a half hour without electricity! I had to take it off to change steering columns, and I carried it like a claymore mine!!
W/R grounding, I normally think of loose or corroded screws being the problem. Any idea what's needed for a good horn ground in the steering wheel?
I am assuming (there I go again with that) that the problematic ground is in the steering column or very nearby.
Thanks!
From: The reason time exists is so everything doesn't happen at once
Just install an air horn from an 18 wheeler, use a shot of nitrous to power it.
Seriously, if you're going to do anything near the air bag disconnect the battery and, for good measure, pull the fuse. Then go have a beer and wait about a 1/2 hour.
OK! I had a beer, pulled the fuse, disconnected the battery and pulled the airbag!
Cleaned the contacts on the horn switches with an eraser and reseated the spring loaded contact in the steering column. I think that was the prollem all along. it seems to have some sort of bayonet type tab that puts some load on the spring. It wasn't engaged when I pulled it out, but after examining it and shining a light into the steering wheel hole, I deduced that I might need to try to engage the bayonet.
Anyway, I put the airbag back in, tightened everything back up and reconnected the battery.
Voila, I have a working horn. Now there is no need to risk frostbite driving with the window down in order to be prepared to use the alternative signaling device that Railroadman suggested!!
Thanks to all for the insights (especiallly relevant to determining if the horns themselves were at fault) advice and encouragement.
When i first bought my 96, the horns did not work.
My corvette expert said they probably shorted out from water damage because of their location in the front bottom area. he replaced the horns and they work now.
