Before you put in new side grills, consider that the grill s you got are already pretty nice. (I have a 93 as well). If you want to make your car stand out. somebody makes a light kit to go behind your grills and cast a led light through the openings. I saw the pics and thought- That's pretty neat. If I find it again, I'll post a link here.
Just a thought!
Just a thought!
well i kinda like the 90s stile with the 2 slits but the one i have now is crack and im getting ready to repaint the car so i figured i should get the side grills b4 i did....but on the top of my side grills on it now is a strip that sticks out? i dont believe the double slit has that?
You do realize that the 84-90 pieces have a different molding, right? I'm pretty sure they still bolt right up, but they won't match your car's wide molding. If you stick with 91+ your molding will match.
ok thanx bud thats what i was trying to find out...so will the 96 molding match up?
Just a thought!
does anyone know anything about these grill lights?
The 95-96 style will fit no porb, plus I personally hated the 91-94 style so I put 95-96 on my 94.
Exactly,cant stand the 91-94 fender panels.Ive got the 95 panels on my 91.Ive seen these 95-96 panels new on Flea bay for about $140 a set or look for used at about half of that.
