Cutting the air box
Old Mar 2, 2010 | 10:15 AM
joesgulfstream's Avatar
joesgulfstream
Default Cutting the air box
I am sure some where here there is instruction and pictures on how to make the cuts in the air box for more air on a 95. Can't seem to find it. Thanks
Old Mar 2, 2010 | 10:37 AM
Klondike's Avatar
Klondike
Is there any evidence to show that it really works? I might do it if I knew it wasn't just a waste of time.
Old Mar 2, 2010 | 11:09 AM
markKlein's Avatar
markKlein
waste of time, IMO
Old Mar 2, 2010 | 11:27 AM
Churchkey's Avatar
Churchkey
There is a pic of a stock air filter on this board that shows the front of the air filter. It is dirty in the areas directly behind the louver openings, the rest of the filter is relatively clean.
Old Mar 2, 2010 | 11:31 AM
pologreen1's Avatar
pologreen1
You already cut the lid?
I though about butchering up my stocker all over the place too, but I don't think it will help any.
Yes there is a thread where a guy made cut outs all over the box.
Old Mar 2, 2010 | 11:49 AM
joesgulfstream
No I did not cut it. I heard besides letting more air in it sounds good
Old Mar 2, 2010 | 12:14 PM
pologreen1's Avatar
pologreen1
Just cut around the vents on the lid, so there is a huge hole. I did mine in 5 minutes with a cut off wheel.
Old Mar 2, 2010 | 12:19 PM
joesgulfstream
how did it sound any different ? I have an auto,95
Old Mar 2, 2010 | 12:28 PM
pologreen1's Avatar
pologreen1
Not really, you might hear more sucking when the hood is open, but no real difference. remember it only removes the vents. If you look at the housing it self, on my 90" at least, there are 2 little holes that the air goes through, so maybe cout out the inside of the box, where the tub connects to the TB.
I did hear a major difference in the Ram air unit I installed. Even driving at higher RPM's I can hear it swooshing when I punch it.
Old Mar 2, 2010 | 04:36 PM
joesgulfstream
What brand is the ram air and how much ?
Old Mar 2, 2010 | 05:17 PM
dogfish246's Avatar
dogfish246
Here is some info and dyno numbers to back it up... Food for thought! Nice read too!
http://www.vetteweb.com/tech/vemp_06...dup/index.html
Old Mar 2, 2010 | 05:26 PM
floridamale's Avatar
floridamale
Just tape off the area you want to remove and use a jig saw follow the tape lines for a even cut
The other thing you can do is remove the black paint from the lid and sand and polish it. It's aluminum looks good after you are done.
Old Mar 2, 2010 | 05:30 PM
dogfish246's Avatar
dogfish246
Any pics of the polished box????
Old Mar 2, 2010 | 05:55 PM
floridamale
Old Mar 2, 2010 | 06:00 PM
Vette Jockey's Avatar
Vette Jockey
Roadster Madness. 😠
St. Jude Donor '13, '20-'21
I wanted to be able to go back to the stock box for shows, so I bought the BPP lid with the K&N replacement from Mid America (PN 603-962). That article was right, it was a bear to put on. I finally ended up using a thinner foam and that worked fine.
I have a '95 auto, too, and do not really notice that much of a difference. 3 BHP sounds about right. I do not notice a difference in sound. I also do not notice a dirt pattern on the filter.
I do make the change to the open box after the show, so I do think it helps with the larger MAS, and air foil.
Old Mar 2, 2010 | 06:06 PM
dogfish246's Avatar
dogfish246
That looks Real Nice!
To Cutting the air box
