Coolant Path/Travel??
Old Mar 5, 2010 | 12:32 PM
Donne Trav's Avatar
Donne Trav
Default Coolant Path/Travel??
('94 LT1): When does the coolant enter the plastic "coolant recovery" tank? Is the recovery tank part of the "normal" path for the coolant or
do special circumstances have to take place, ie: abnormal tempts or
overheating. Also. should the coolant level be at the "hot" mark of the tank always during normal engine operation? Thanks
Old Mar 5, 2010 | 07:21 PM
RollaMo-LT4's Avatar
RollaMo-LT4
St. Jude 15 Year Donor
2021 C4 of the Year - Unmodified Finalist
St. Jude Donor '10 thru '25
If your talking about the recovery tank down low in the front passenger side wheel well, then no, that recovery tank is not really part of the normal flow path.
Your cooling system is under pressure, and you can see that recovery tank is not.
So, coolant will only enter the recovery tank under certain high pressure conditions. Then as the system begins to cool down again, the coolant is sucked back into the main surge tank (the black plastic tank by the firewall).
I wouldn't worry about having the coolant level up at the full "hot" mark exactly. You don't want to go over that line though, and you don't want the tank completely empty either.
