Starting issue
Old Mar 5, 2010 | 06:50 PM
BobRR3's Avatar
BobRR3
Default Starting issue
this just started last week. I tried to start the car, 96 LT1, Turned the key and just a click. Tried again and it started right up. I thought maybe i jsut didn't turn the key long enough enough. then It happened three times befor the car would start. Once the car starts, It runs fine. The battery is new. I looked in the FSM and there are several things i need to check. I'm just looking to see if anyone else has had this problem to point me in the right direction.
Things i plan on checking : the stsrter itself
the theft deterent system
Transmission switch
Would any of these , other than a bad starter even allow the starter motor to click? I wouldn't think so.
Old Mar 5, 2010 | 06:56 PM
HdRider04's Avatar
HdRider04
You said a new battery, check and retighten your positive and neg cables.
Old Mar 5, 2010 | 06:57 PM
BobRR3's Avatar
BobRR3
Yes, that's the first thing i checked thanks
Old Mar 5, 2010 | 07:07 PM
RetiredSFC 97's Avatar
RetiredSFC 97
St. Jude Donor '09-'10, '14
Could be solenoid in the starter. I would also check connections on the starter first. Might as well check to see if you have any codes as well.
Old Mar 5, 2010 | 10:31 PM
avgjoe's Avatar
avgjoe
Check connections, including the ground connection, and if it persists it sounds like the starter solenoid.
Old Mar 6, 2010 | 08:50 PM
plmkrzy's Avatar
plmkrzy
Probably the starter. I had the same problem until it just didn't start. I replaced the whole shebang to be sure and disco'd the vats system since I had that problem a few years ago on my '94.
To Starting issue
